Removing Old Carpet, Left Over Glue...best Way To Remove It? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-23-2009, 08:21 PM   #1
Rewards Points: 408
Removing old carpet, left over glue...best way to remove it?
I'm remodeling the basement and I'm removing the old crappy rug. Under the rug was padding and the padding was put down with some type of adhesive. Is there an easier way of getting this up, it takes me about 15 minutes to scrape up a couple square feet.
In the picture, the white spots are the actually cement floor while the brown is the glue.
Removing old carpet, left over glue...best way to remove it?-floor_issue.jpg
RyanD is offline   Reply With Quote
Old 06-24-2009, 07:25 AM   #2
True Player
G-Fish10's Avatar
I can't really see the texture of the glue from the picture, but if it's flat for the most part, you could go ahead and lay your new floor right over it. This would also depend on the type of floor you were gonna put in, too. What are you planning on putting over it?
G-Fish10 is offline   Reply With Quote
Old 06-24-2009, 08:08 AM   #3
Rewards Points: 408
I'm guessing we couldn't tell the difference if we put carpet back down right? We're not sure if we're going hardwoods or carpet yet plus I need to build some walls so the floor has to be level for that too.
Old 06-24-2009, 08:48 AM   #4
True Player
G-Fish10's Avatar
Yeah I wouldn't worry about tearing it up anymore if you're gonna put more carpet down, or laminate or tile for that matter. If you opted for hardwood, you would probably have to go with a glue down type since you can't staple into cement, and any adhesive that you use should go fine on what's already there.
Old 06-24-2009, 01:31 PM   #5
Rewards Points: 1,016
power scraper
I rented a power scraper from Home Depot when faced with similar - took it up fairly easily, much easier than by hand.
Old 06-24-2009, 04:37 PM   #6
Try heating it with a heat gun, that should soften it enough to scrape it up with a putty knife.
SKIP4661 is offline   Reply With Quote
Carpet cleaning - sump water n0c7 Flooring 17 08-29-2011 07:04 AM
Laminate flooring over old glue?? TomC723 Flooring 2 08-19-2008 12:33 AM
Removing contruction glue from dry wall old&bald Remodeling 2 06-07-2008 10:11 PM
Removing carpet pad and paint from hardwood floors Rahci Flooring 10 05-14-2008 01:54 PM
