Removing Mirror Tiles From Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 12:48 PM   #1
Rewards Points: 89
removing mirror tiles from wall
i'm going to be removing an entire wall of 1' by 1' mirror tiles. they are glued to the drywall.
any hints or tips? thanks!
19mquinn79 is offline   Reply With Quote
Old 03-14-2011, 01:29 PM   #2
Experienced
Jackofall1's Avatar
Other than prepare yourself for years of bad luck
Wear gloves safety glasses and have a couple of boxes to insert broken pcs into as they come off the walls.
I had to do the same thing a few months ago, used a small pinch bar and surprisingly enough many came off without breaking.
Most garbade collection will not take mirror, as it is considered hazardous material, you will have to drop it at a recycle center for hazardous waste.
Mark
Skim Coating wall After removing wallpaper stevenson66 Painting 6 11-08-2010 08:35 PM
removing wall, making arc, need to determine dimensions ilyaz Kitchen & Bath Remodeling 1 03-03-2010 07:30 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 12:14 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
