Removing Metal Corner Bead - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 09:09 PM   #1
Rewards Points: 492
removing metal corner bead
In the short term, I am hoping to avoid having to remove the tile to repair the bathroom wall. But to do that, I need to remove the metal corner bead that is behind the shower tile/backer board. I haven't had any luck cutting it with snips. Would a hacksaw work, or am I forced to remove the tile?
Thanks for taking a look! (more details are linked below)
more details than you ever needed here
joetab24 is offline   Reply With Quote
Old 06-13-2012, 09:18 PM   #2
I have used a utility knife and a hammer to slice corner bead on more than one occasion. Just go in at an angle then turn till you are vertical light to moderate taping is all that is needed but it may damage your knife so use an old one.
kj6887 is offline   Reply With Quote
Old 06-24-2012, 12:00 PM   #3
Rewards Points: 492
metal corner bead/drywall crack
moved to drywall forum
Corner Bead Repair? How? kennykenny Painting 5 01-25-2012 07:55 PM
Corner bead wraiththe Tiling, ceramics, marble 0 12-19-2011 11:37 AM
corner bead crack igneous Drywall & Plaster 4 02-08-2011 02:11 PM
Ceiling corner bead kchopper Drywall & Plaster 8 03-18-2010 11:36 AM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
