Removing Glued Wainscoating - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-15-2007, 11:48 AM   #1
removing glued wainscoating
my living room has glued wainscoating. I hate it!! how do i take it off without destroying the walls?
diysteph is offline   Reply With Quote
Old 07-15-2007, 12:31 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If it's construction adhesive, or any other kind of hardened adhesive/glue, then you are going to have: destroyed walls.
(If it was caulking of some kind, then you would have a chance at scraping it off and skim-coating over the areas)
However, with hardened adhesives or glue....
I would suggest that you just rip it (wainscotting) off. Then remove the sheetrock with adhesive stuck to it, at 48-1/2" up.
Replace with new sheetrock butted up tight to the existing areas. Tape and Coat.
- Build Well -
Old 07-15-2007, 01:19 PM   #3
thanks, i guess i just paint over it.
Old 07-16-2007, 01:42 AM   #4
Rewards Points: 150
I wonder if you could try getting it off the same way you take mirrors off walls. That would be using something like a long string of thin wire (sometimes even dental floss works) like picture hanging wire and using it to 'saw' the back of the wood off the wall, from top to bottom through the adhesive. The trick would be finding a way to get the string behind the wainscotting in manageable widths (say 36" or so at a time). Gloves are a good idea if you can do it.
This worked really well for me when removing a very large mirror that had been glued to the wall. It had both a soft type adhesive and a very hard one (guessing one was used to hold while the other cured or something). After I could get most of the glue off with a razor blade and a bit of sanding. The walls remained in much better shape than I expected.
Thinking about doing an entire room, that could be a huge job to undertake and it may be quicker to just rip the stuff off and replace the drywall.
Dusty is offline   Reply With Quote
Old 07-16-2007, 04:38 AM   #5
Originally Posted by Dusty View Post
I wonder if you could try getting it off the same way you take mirrors off walls....
That last point is "Dead on". ....That would be a tedious and lengthy project.....
- Build Well -
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 10:37 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 11:53 AM
removing knockdown texture K_I37 Painting 7 05-07-2006 01:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
