Removing Glass Of Casement Window - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-09-2010, 10:28 AM   #1
JPM
Bill Traver
Rewards Points: 93
Removing Glass of Casement Window
I have a rental property where someone broke the outside pane of a casement window. I'd like to take it to a glass place and get the pane replaced.
I am not familiar with working casement windows ... I only have experience with replacing the glass on standard types.
My question is that I have never had to remove a casement window before. These happen to be Andersen windows. How do I do this?
thanks!
JPM is offline   Reply With Quote
Old 02-09-2010, 10:39 AM   #2
Rewards Points: 5,336
Andersens have removeable plastic caps on the exterior. Carefully remove them. The glass will be caulked in place. You will need to cut the caulk to release the glass. You will probably need to cut the caulk from the interior as well. Keep track of the spacer blocks that mikght be behind the plastic covers. You'll need them on the reinstall.
You might be able to call a local window place to order one in advance if they're familiar with the Andersen setup, oterwise have some plywood handy to temporarily fill the space while to get the replacement.
Andersen might have a more detailed explanation on their website.
Ron
Old 02-09-2010, 10:55 AM   #3
JPM
Bill Traver
Rewards Points: 93
Ron,
Thanks for the reply ... this is a second floor window, so I'd like to take the thing down before work starts ... is there any secret to dismounting it off its "hinges/pins"?
Old 02-09-2010, 11:16 AM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
There are little sliding retainers on the arms. You'll see a flat groove where you can insert a flat head screw driver to move it. Once you do so you can lift the arms off the pegs, then slide the window out of the tracks. It is highly advisable to do it with two people (one inside and one out.)
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Casement window doesn't close all the way jasontal Building & Construction 1 08-23-2009 09:23 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
