Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-13-2005, 10:18 PM   #1
Removing doorknob
Hi
new here. need help in getting an old outside doorknob off. Have searched the web for help, can't find the same knob anywhere. Instead of the usual detent slot , this knob has a small hole. Have tried to stick a small nail to release the knob to no avail. Any ideas??
allhorses50 is offline   Reply With Quote
Old 11-15-2005, 02:49 PM   #2
Removing doorknob
Hi
Is there a small grub screw at the bottom of this hole? If its old it may be covered in grime so try turn it with a small screwdriver (flat headed) If there is no screw then this knob may have rusted itself on over the years due to its exposed condition. You may have to resort to brute force if a liberal application of WD40 doesn't work!
The trick is to apply force evenly around the knob, try cutting two wedges out of softwood that just fit behind it, then with two hammers strike downward until it loosens off.
I would have thought that taking the inside one off would enable the whole unit to be slid out but its hard to say without taking a look!
Cheers
nicknackynoo is offline   Reply With Quote
