Removing Door Latch - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 10:00 PM   #1
Unhappy
Removing Door Latch
While remodeling a bathroom, the wife has decided that she'd like all the door latches in the house replaced. The house is 40 yrs old, and these are the originals, so I guess it's justified. I started with a closet latch that was broken, and all the latches seem to be the same. After removing the knobs, I am having trouble getting the latch mechanism out. It doesn't have a retaining plate with screws on the door edge, it's round, and seems to be pressed in. Got it started out, but it doesn't want to come,...seems to be a plastic bushing around it, that is holding it. Anyone seen one of these ?
Malibujim is offline   Reply With Quote
Old 02-21-2011, 10:44 PM   #2
Rewards Points: 5,336
If the knobs and lock mechanism is removed, just place a screwdriver through the spindle hole and tap it to the front of the door. Once the first 1" is exposed, you should be able to pull it out by hand.
Ron
Old 02-21-2011, 11:08 PM   #3
Nope. It is pushed out far enough that it is just clear of the round hole, but really binds up at this point.
Old 02-22-2011, 06:20 AM   #4
Keep going, it went in that way and it will come out that way. Try prying out the bushing.
Old 02-23-2011, 05:50 AM   #5
Removing Door Latch
Good job…doorknob has screws on the cover plates; remove those to loosen the old knob. If not, look for a small slot with a metal piece on the side of the handle. Depending on your door, you may need to adjust the backset, the distance between the edge of the door and the center of the doorknob. Most doorknobs can accommodate different backsets. Test the new handle to make sure it turns and locks properly.
Blue Heron is offline   Reply With Quote
Old 02-23-2011, 05:28 PM   #6
OK, got it. What seemed to be plastic, was actually a metal sleeve, around the latch. It had little barbs on the OD,...meant to go in, but not come out. As it did start to come out with the latch, but then bound up, I had to tap it back in using a screwdriver blade, and then the latch came out. To remove the sleeve, I had to tap it into the 2" hole for the knobs.
Removing old grass with tiller? gante Landscaping & Lawn Care 36 05-08-2013 02:26 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
Removing Laminate Backsplash??? mjkpainting Remodeling 13 06-22-2009 11:58 AM
prep walls after removing paper ponch37300 Painting 1 01-10-2009 10:54 AM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
