Removing Curtain Track In Ceiling And Repair - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-25-2010, 01:39 PM   #1
elllie's Avatar
Removing curtain track in ceiling and repair
Hi
I'm new to these forums so I hope I'm posting this in the right forum.
My problems is that I'm renovating a 1950s flat. The ceiling in the lounge was covered in polystyrene tiles which, when removed, revealed a metal curtain track which had been "sunk in". We've been able to remove the track but underneath, there's a further metal track which can't be removed without extensive ceiling damage which will prove too costly for our budget.
What we need to do is to fill the gap which is about 6ft long and 3-4 cms deep. I'm thinking of filling it layer by layer with standard filler/plaster but I'm worried that it may fall out because of the metal track. Can anyone help please? Thanks very much.
elllie is offline   Reply With Quote
Old 04-25-2010, 02:30 PM   #2
Rewards Points: 5,336
What is the ceiling constructed from? Plaster? How wide is this space? If it's 1 1/2" deep(4cm) you can screw in a 3/4" board covered with some sheetrock. Tape and compound the entire length. After 2-3 coats, you can repaint the ceiling.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
elllie (04-25-2010)
Old 04-25-2010, 03:15 PM   #3
elllie's Avatar
Thanks Ron - the gap is 3 cm wide but as there's a metal strip still embedded, I'm not sure how I could screw into it. It's a plaster ceiling. I'd thought of using a strip of plasterboard (is this the same as sheetrock?) but I'm not sure. I'm worried that whatever i fill it with won't be able to grip due to the metalwork.
Old 04-25-2010, 03:45 PM   #4
You drill the metal so you can screw up the material. You need the mechanical fasteners to keep it secure. You can probably use self tapping screws to screw the wood up and short drywall screws for the sheetrock or plasterboard.
If you're uncomfortable with that scenario, you can use the proper construction adhesive to hold it in place. You will need to prop it up until the adhesive dries.
Ron
Ceiling Leak Stain Repair Help Please ltkenbo General DIY Discussions 2 09-13-2009 06:38 PM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
Textured ceiling Sheetrock repair theatretch85 Building & Construction 10 02-25-2009 05:14 PM
Ceiling Crack Repair Speckert Building & Construction 7 12-29-2008 10:03 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
