Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-13-2009, 11:32 PM   #1
Removing clay stains from asphalt
Does any one know how to remove clay stains from asphalt?
I foolishly left some clay footprints on a neighbour's new asphalt and the acid in the clay has stained it.
She tried to scrub it off with a broom and water to no avail.
Any assistance will be appreciated.
Len
ljcox is offline   Reply With Quote
Old 05-14-2009, 04:52 AM   #2
If clay is that prevalent in the area, why bother? Your footprints, her footprints, the dogs footprints, car tires, etc...
Best way to neutralize an acid, is with a cleaner that's a base.
Ron
Old 05-14-2009, 10:52 PM   #3
Ron
Thanks Ron,
She allowed me to dispose of my clay in her yard in order to fill a depression.
The clay is where no-one walks and it will be covered by grass eventually.
The foot prints were mine as I walked on the clay to compress it.
It may be too late to use a base since the chemical change has already happened.
What do you think?
Len
Old 05-15-2009, 12:02 AM   #4
Drywall Contractor
LadyFinisher's Avatar
try a pressure washer and bleach
LadyFinisher is offline   Reply With Quote
Old 05-15-2009, 12:45 AM   #5
Love for Construction
<*(((><'s Avatar
I used to be a superintendent for a local home builder in an area, where the dirt had a lot of clay in it. We would often get stains on a newly poured sidewalk and driveways of our homes, we would use muradic acid with a plastic bristled push broom. It etches the concrete if left on too long without rinsing with water and requires some muscle with the broom, but worked for us on several occasions. Be sure to follow the warnings on the bottle and read the MSDS sheet that should be provided with it.
<*(((>< is offline   Reply With Quote
Old 05-15-2009, 09:35 PM   #6
Thanks LadyFinisher and *<(((><.
*<(((>< it is asphalt - not concrete.
Would muradic acid work on asphalt?
Len
Old 05-15-2009, 09:54 PM   #7
There's nothing but clay soil around here. With all the construction around here, it gets on the asphalt roads all the time. After a good rainfall, there's no signs of the clay.
Most likely, the clay is stuck to the asphalt and didn't actually etch it. It should wear off shortly.
Don't try muriatic acid as it will just damage it and leave spots where you use it.
A light pressure washing or steam cleaning may work but you'll want to do the entire walkway or you'll be able to see where it was cleaned and where it wasn't
KHouse75 is offline   Reply With Quote
clay cap around foundation? patrickosu Building & Construction 5 08-21-2010 05:55 AM
Removing asphalt shingles stevez Roofing 5 04-27-2009 04:35 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 11:51 PM
Removing stains in hardwood flooring Max1119 Flooring 5 07-03-2008 07:19 PM
Removing water stains bead board Mikon Painting 5 10-08-2007 05:57 PM
