Removing Carpeting From Concrete - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 12:39 PM   #1
removing carpeting from concrete
the fun begins, i have already lifted the carpet and padding along with the tack board i am currantly using a heat gun ( i plan on painting the concrete so any chemicals are out)
However the padding left a nice fuzzy border surrounding the basement the heat gun just burns it even at its lowest setting scraping isnt cutting it what are Your thoughts on power sanding ? will this cause a variation in this part of the cement?
BECK5791 is offline   Reply With Quote
Old 04-07-2009, 05:42 PM   #2
Rewards Points: 272
I would use a floor scraper it is available from your local home improvement centre. You can get one with a 4 or 6 inch blade. They can also be re-sharpened when they dull.
cheers
fixrite is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Help on removing concrete stairwell going into Basement. earthad1 Building & Construction 13 03-29-2010 02:59 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
Removing Concrete Ridge and Ground Protection on Ground Floor RayIII Building & Construction 1 10-09-2008 03:36 PM
