Removing An Added Exterior Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-23-2014, 03:00 PM   #1
Removing an added exterior door
I'm removing an exterior door in a bedroom that was added for some reason. I want to finish the opening as if it had not been there. My question is do I need tar paper or some kind of vapor barrier between the siding and insulation?
Thanks in advance!
Stemoc is offline   Reply With Quote
Old 05-23-2014, 03:44 PM   #2
Rewards Points: 6,652
Post pictures of the outside and inside. Most likely the door was added for the person that used that bedroom to exit outside. Without having to go through the house (ie renter).
You would need to look behind the existing siding, to find out what they did between it and the house sheathing.
Old 05-23-2014, 04:09 PM   #3
Rewards Points: 13,270
What type siding is there?
Old 05-23-2014, 05:06 PM   #4
MarginallyQualified
Rewards Points: 2,464
On a scale 1 to 100.. how important are the cosmetics to you?
Old 05-23-2014, 08:43 PM   #5
Rewards Points: 220
EZ. Pull out the door.put on some house wrap on the outside and integrate the siding in. Insulate the space. Put a vapor barrier on the inside. Rock and/or whatever the inside is, done and done. No worries. Ron
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
Stemoc (06-01-2014)
Old 05-25-2014, 05:07 PM   #6
Registered User
Rewards Points: 5,216
I would skip the interior vapor barrier for Texas...IMO.
Gary
Old 05-25-2014, 09:29 PM   #7
Rewards Points: 220
I might too. But I checked the ops profile and it didn't give a state?? What did I miss?.ron
Old 05-25-2014, 10:33 PM   #8
Registered User
Yes, I try to answer per location, also. Why people think insulation/ventilation, vapor barriers and rainscreen siding are not location specific, is beyond me, they just don't realize how important local conditions are, I guess. Tried to get it as a requirement when signing on but to no avail, when I was a mod. Click on the name, then posts- then read the exerts. Easy to miss, been there- done that, lol...
Gary
Old 05-26-2014, 06:33 PM   #9
Man of many hats
wrangler's Avatar
Rewards Points: 354
It was in on of the OPs earlier posts and introduction. not that you should HAVE to do research to answer a post.
Man of many hats
wrangler is offline   Reply With Quote
The Following User Says Thank You to wrangler For This Useful Post:
Gary in WA (05-26-2014)
Old 05-27-2014, 07:32 PM   #10
Thanks for the replies. The was built in '52, therefore no insulation.
Old 06-01-2014, 12:46 PM   #11
Rewards Points: 494
You may want to keep the door. Almost all building codes, you need a means of escape to qualify as a bedroom.
carpdad is offline   Reply With Quote
Old 06-01-2014, 09:02 PM   #12
Code here is the window must be able to be opened. The bedroom is per code.
Removing wall mount sink connector OldHomeJen Plumbing 6 11-27-2013 09:45 AM
I added Nu Calgon StopLeak to high pressure side... dan!mal HVAC 12 07-08-2013 02:22 PM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 06:52 PM
prep walls after removing paper ponch37300 Painting 1 01-10-2009 11:54 AM
Removing old thinset from subfloor gburg3 Flooring 3 12-15-2008 08:59 PM
