-   -   Removing an added exterior door (http://www.diychatroom.com/f2/removing-added-exterior-door-201213/)
Stemoc 05-23-2014 02:00 PM
I'm removing an exterior door in a bedroom that was added for some reason. I want to finish the opening as if it had not been there. My question is do I need tar paper or some kind of vapor barrier between the siding and insulation?
Thanks in advance!
gregzoll 05-23-2014 02:44 PM
Post pictures of the outside and inside. Most likely the door was added for the person that used that bedroom to exit outside. Without having to go through the house (ie renter).
You would need to look behind the existing siding, to find out what they did between it and the house sheathing.
joecaption 05-23-2014 03:09 PM
What type siding is there?
TarheelTerp 05-23-2014 04:06 PM
On a scale 1 to 100.. how important are the cosmetics to you?
ront02769 05-23-2014 07:43 PM
EZ. Pull out the door.put on some house wrap on the outside and integrate the siding in. Insulate the space. Put a vapor barrier on the inside. Rock and/or whatever the inside is, done and done. No worries. Ron
Gary in WA 05-25-2014 04:07 PM
I would skip the interior vapor barrier for Texas...IMO.
Gary
ront02769 05-25-2014 08:29 PM
I might too. But I checked the ops profile and it didn't give a state?? What did I miss?.ron
Gary in WA 05-25-2014 09:33 PM
Yes, I try to answer per location, also. Why people think insulation/ventilation, vapor barriers and rainscreen siding are not location specific, is beyond me, they just don't realize how important local conditions are, I guess. Tried to get it as a requirement when signing on but to no avail, when I was a mod. Click on the name, then posts- then read the exerts. Easy to miss, been there- done that, lol...
Gary
wrangler 05-26-2014 05:33 PM
It was in on of the OPs earlier posts and introduction. not that you should HAVE to do research to answer a post.
Stemoc 05-27-2014 06:32 PM
Thanks for the replies. The was built in '52, therefore no insulation.
carpdad 06-01-2014 11:46 AM
You may want to keep the door. Almost all building codes, you need a means of escape to qualify as a bedroom.
Stemoc 06-01-2014 08:02 PM
Code here is the window must be able to be opened. The bedroom is per code.
