Remove A Screw - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 07:50 AM   #1
Remove a screw
How can I remove a screw which head has been rounded off, and therefore I cannot get a screw driver in. The screw is holding the front of a integrated dishwasher front.
gpowell52 is offline   Reply With Quote
Old 03-03-2008, 09:28 AM   #2
wfischer's Avatar
If you can grab the head with a pair of pliers, that'd be the simplest way. Vice grips would probably be your best bet. If pliers won't work, then you'll probably have to get one of those special screw removal tools.
wfischer is offline   Reply With Quote
Old 03-03-2008, 01:53 PM   #3
Rewards Points: 1,910
Two other options:
1) enlarge the slot with a dremel with a cutting disc, the use screwdriver.
2) Use a drill bit the approx diameter of the screw shaft and drill straight into the head. When the head pops off you can remove the dw front and then remove the rest of the screw by grabbing the shaft with vice grips.
Old 03-03-2008, 03:57 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Can you re-cut a new slot into it and try do back it out?
- Build Well -
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 08:18 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
Ground screw in 4" box fw2007 Electrical 8 10-05-2007 03:07 PM
Screw in Track Lighting Bar Popping Out SueC456 General DIY Discussions 5 03-13-2007 07:24 AM
