Remove Rust Cast Iron Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-09-2008, 06:51 PM   #1
Smile
remove rust cast iron tub
How do I remove a major amount of rust from a very old white cast iron tub?
workingirl is offline   Reply With Quote
Old 01-09-2008, 07:18 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 360
Ayuh,....... That Depends,......
Are you trying to rescue the original porcelain surface,...??....
Or,....
Are you preping the surface for a refinish,..??.......
CLR, with rubber gloves, safety glasses,+ a plastic scrubby pad can do Wonders if you're attempting the Rescue.........
Bondo is online now   Reply With Quote
Old 01-09-2008, 11:37 PM   #3
Bathtub Refinisher
Be careful with CLR. It is a very strong acid that will not only remove the rust but will also damage the remaining glaze on the bathtub.
Mike
tubguy is offline   Reply With Quote
Old 01-10-2008, 08:30 AM   #4
removal of rust
I am attempting to rescue the tub, but if not, what would be the procedure on preparing the surface for refinishing?
Old 01-10-2008, 08:34 AM   #5
What section of the tub is the rust on?
redline is offline   Reply With Quote
Old 01-10-2008, 08:34 AM   #6
tubguy}; looks like there is very little glaze left a sit is. Best to just prepare surface for refinish? Refinishing????? How does that procedure usualy turn out? Can you tell it has been refinished? By the way this is a flip house I am working on,{lower income area}.
Old 01-10-2008, 08:36 AM   #7
redline}; rust covers pretty much all the bottom and about 25% of the sides.
Old 01-10-2008, 10:02 AM   #8
Bathtub Refinisher
That sounds like soap scum. Rust is generally around the drain area due to leaky faucets. What you are describing sounds like soap scum. To verify take a razor blade and scrap it. If it comes off then it is not rust.
Mike
Old 01-10-2008, 10:40 AM   #9
tubguy} Hummmm, that is very interesting. i suppose because of the rust color i just assumed it was rust. Thank you very much. I will give that a try.
Old 06-15-2008, 10:16 AM   #10
Mine is definitely rust
Hey its been a while since anyone posted here. But I have this problem. Its definitely not soap scum. Its just rust spots around the circular metal disk under the faucet. I just want to remove the rust, and seal it up in order to prevent any further damage.
skembree is offline   Reply With Quote
Old 06-15-2008, 11:13 AM   #11
Rewards Points: 5,336
It sounds like you have a steel washer under the escutcheon plate that's rusting. Unless you take it apart and replace it, it will continue to bleed through forever.
Ron
Old 08-20-2008, 10:25 PM   #12
Old cast iron tub
I have an old cast iron tub that I would like to use but it has rust all over the floor part. Person used this tub before had rubber mat( that one you don't slip) and have never taken bath but shower. It rusted entire bottom( floor ) part. As "workingirl"s post I would like to rescue this tub. Please let me kow if any one has any good way to get rid of that or should I refinish the surface...
miki3lotus is offline   Reply With Quote
Old 08-21-2008, 10:58 AM   #13
1610 CUB's Avatar
Rewards Points: 150
This should clear up your rusted tub
http://www.purelyusa.com/manufacture...nufacturerid=1
1610 CUB is offline   Reply With Quote
Old 08-23-2008, 03:41 PM   #14
Thank you!
I will research it and try it!!!
Thank you so much!
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 11:35 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 11:58 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Current trends: Cast Iron or Stainless Steel sink? Fat b Remodeling 4 05-04-2007 08:09 PM
