Remove Rust From Cast Iron Bed Rails - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2008, 10:15 AM   #1
Remove Rust from Cast Iron Bed Rails
Can anyone recommend a way to remove rust from cast iron bed rails? The bed rails are antiques. I just want to clean them so I can use them, I am not worried about trying to preserve the finish or any special markings. Thanks.
cpalmer67 is offline   Reply With Quote
Old 01-16-2008, 11:23 AM   #2
wfischer's Avatar
wd-40 and a wire brush should work well.
wfischer is offline   Reply With Quote
Old 01-16-2008, 11:57 AM   #3
naval jelly
Big Bob is offline   Reply With Quote
Old 01-16-2008, 01:27 PM   #4
Rewards Points: 530
electrolysis (spelling) and a kid's pool? This is not hair removal . Try googling electrolysis and rust/paint removal. Battery charger, water and Arm & Hammer detergent ( not baking soda). If you go this route, pay attention to safety precautions due to the gases that may be released. I did part of an old cast iron stove, but I did it outside.
Old 01-16-2008, 02:18 PM   #5
Do you have a picture? I've never seen a cast iron bed.
NateHanson is offline   Reply With Quote
Old 01-16-2008, 04:04 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,.........
I've seen Cast Iron footboards,+ headboards,..... But not rails.......
It really depends on the Finish you want to end up with,.......
If you want it back to the grey Metal state,....... Sandblasting is pretty hard to Beat........
If you're trying to knock off the heavy rust,+ then repaint it,...... A Wirebrush would probably do.......
'course,....... There's Abunch of ways to Chemically Etch it,...... 1 of which is noted above......
Old 01-17-2008, 09:37 AM   #7
Thanks everyone for your help.
Old 01-17-2008, 10:14 AM   #8
Rewards Points: 195
Rusty metal
I wire brushed the scales off some iron porch rails a few years back and brushed on "Rusty Metal Primer" and applied glossy black paint when it dried. They still looked great two years later when I sold the house. The primer was in the rustoleum area of the hardware store but I think it might have been a Red Devil product. It came in pint and quart cans. Oh yeah, I have an old farm bell I also did and it still looks great. I painted it with flat blck paint so the pitting wouldn't be obvious.
Arlo is offline   Reply With Quote
Old 07-24-2009, 03:25 PM   #9
Question
What else do you find in the rustoleum area of the hardware store?
bustersean is offline   Reply With Quote
Cast iron vs galvanized steel. duffers Plumbing 10 08-04-2009 11:35 PM
remove rust cast iron tub workingirl General DIY Discussions 13 08-23-2008 03:41 PM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
Help with Cast Iron Material Tester Plumbing 2 10-25-2007 11:58 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
