Remove Plate From Woodstove? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 01:18 PM   #1
Rewards Points: 99
Remove plate from woodstove?
The woodstove in my cabin has a metal plate inside the goes from the bottom rear to the top of the front. I guess it so the heat gets pushed out but it also pushed a lot of smoke out at times. Can it be removed without creating any problems and what was its purpose?
panteramatt is offline   Reply With Quote
Old 09-13-2012, 02:37 PM   #2
the Musigician
DangerMouse's Avatar
It sounds like the (reburner?) that makes the stove more efficient. I would leave it be and check your chimney to be sure it doesn't need cleaning. There are other things that may be the (smoke) problem as well, but it's not likely to be the design of the stove.
DM
Old 09-13-2012, 04:19 PM   #3
Rewards Points: 99
I use stove pipe and its hardly been used so it cant be dirty yet. It doesnt take much smoke at all in a small cabin to make it unpleasant. If I remove the plate I could also fit more wood in there, but I dont want to cause more harm than good. Ive just never seen a woodstove with a plate in it before.
Old 09-14-2012, 08:18 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... Sounds like the chimney is to short, 'n ya don't have proper draft...
Old 09-18-2012, 05:38 AM   #5
Rewards Points: 99
Its at least 2 feet higher than the peak. You think it needs to be higher?
Old 09-18-2012, 07:03 PM   #6
Too Short? Cut it Again!
Is the chimney clear of animal nests and things? No soot built up from last season? Any weird bends that could have sagged or is it straight out the top? No dampers closed anywhere? A fave song comes to mind...
Old 09-18-2012, 07:07 PM   #7
Rewards Points: 99
I cant see soot being a problem as it hasnt been used that much at all. Theres 2 bends in the pipe but nothing sags.
Old 09-18-2012, 07:28 PM   #8
Is this a new problem by the way? Any change in what you are burning? You would be surprised how fast soot and other deposits can build up.
Old 09-18-2012, 07:46 PM   #9
Rewards Points: 99
No. It was way worse til I raised the pipe outside.Dont even know how I would check the pipe without taking it apart.
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 10:33 PM
Roof Repair for Cinderblock Garage (Top Plate & Joists) Boiler98 Building & Construction 5 01-06-2012 01:20 PM
2 Gang Wall Plate with one switch and blank? ctandc Electrical 2 12-13-2011 11:39 AM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 04:05 PM
Replace Sill Plate to Basement Block Wall - No anchor bolts DoItMyselfToo Building & Construction 4 09-10-2011 03:07 PM
