Remove Pet Urine Odor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-30-2007, 10:45 AM   #1
remove pet urine odor
Any suggestions on how to remove cat urine from the heat vent?
kathyn is offline   Reply With Quote
Old 06-30-2007, 11:42 AM   #2
Darylh's Avatar
What kind of heat vent are we talking about,forced air, electric??
Darylh is offline   Reply With Quote
Old 06-30-2007, 11:48 AM   #3
Forced air for gas furnace and AC. Have tried pet enzyme odor killer- think the only option is to replace duct.
Old 06-30-2007, 12:13 PM   #4
Darylh's Avatar
Yah thats what I would do to just to be safe
Old 07-01-2007, 04:24 PM   #5
Contractor
Dan101's Avatar
Almost impossible to get it all out. Definately replace the vent if you have that option!
Dan101
Owner
J.& D. Remodeling
Chicago, IL
Dan101 is offline   Reply With Quote
Old 07-02-2007, 12:08 PM   #6
Home Improvement Guy
ron schenker's Avatar
Spray dog urine on it, they will cancel each other out. Just kidding
ron schenker is offline   Reply With Quote
Old 07-03-2007, 11:47 AM   #7
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Its probably not the actual metal duct but the wood, drywall, carpet, etc around it that is contaminated. The metal should clean up pretty easily.
Brik is offline   Reply With Quote
Old 07-04-2007, 11:41 AM   #8
RAD Systems's Avatar
www.odordestroyer.com
RAD Systems is offline   Reply With Quote
Old 07-13-2007, 08:41 AM   #9
Rewards Points: 150
Natures Miracle (avail. at pet stores) works very well I've found, for cat urine smells.
As "Brik" said, it's probably more than just the duct, but the surrounding porous areas that are trapping the smell. You'll need to treat and area probably 1-2 feet from the edges of the duct, all the way around.
curls00 is offline   Reply With Quote
Old 07-13-2007, 03:54 PM   #10
newer than a newbie...
Rewards Points: 87
Carpet in the area?
If you have had carpet in the area, that could be it.
We just replaced our carpet and the old cat urine smell from the previous owner is long gone.
But the possibility of it getting into the wood subfloor might be also an issue.
mcvane is offline   Reply With Quote
Odor under the sink Bob Nau Plumbing 7 05-14-2013 11:09 PM
New Construction Odor Bewildered1971 Building & Construction 12 06-25-2008 10:39 PM
Covering pet odor with laminate kjmenchio Flooring 6 01-16-2007 06:33 AM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 01:07 PM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 05:12 PM
