Remove Grout From Side Of Fiberglass Tub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-30-2009, 12:31 PM   #1
Rewards Points: 14
remove grout from side of fiberglass tub
So, I am finally almost done with my complete redo of my guest bath.
I replaced the old cast iron with a new fiberglass tub. Tiled the floor. However, in my stupid haste, I got grout from the floor/wall tiles on the sides of the tub.
What is an good way to remove the excess grout from the tub? i tried using a razor, but didnt to scratch up the tub.
Can I use something like Kean Acetone? Will that damage the fiberglass finish?
s4alex is offline   Reply With Quote
Old 09-30-2009, 02:05 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
DO NOT use acetone on that tub!
Grout, even tho it isn't water soluable can sometimes be removed easier if it is wet. Soak it with water and white vinegar and THEN use a plastic ice scraper and a sponge and gently go after the grout. I have never had a problem removing grout from anything but you should go slow and be careful. It will come off.
XXX
botched grout/tile job hello1 Tiling, ceramics, marble 10 09-29-2009 04:48 PM
Do I need to grout fireplace tiles? xiard Remodeling 4 04-17-2009 07:19 AM
Cracking floor grout - Ceramic tile DeepDish Building & Construction 9 08-27-2008 09:51 PM
missing grout sum07 Remodeling 2 08-29-2007 01:15 AM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
