Remove Door Knob - No Screws Visible ? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-18-2011, 06:17 AM   #16
Mold!! Let's kill it!
Rewards Points: 2,012
Thread the bushing back in toward the chassis to cover the O-ring. The bushing is probably hiding the poke hole for the knob retainer. No, the knob doesn't thread off no matter how strong you are. There is definitely a spring loaded retainer holding it on. In the at rest position, the retainer should be facing what would be the edge of the door.
Old 05-18-2011, 06:41 AM   #17
NACE Coating Inspector
mustangmike3789's Avatar
really? why would you need to take the other knob off. can't you mount the piece in the door with only one knob off. its not like you need to slide it in backwards or something with both knobs off. i see no need to remove both knobs unless the mounting screws are behind the other one.
mustangmike3789 is offline   Reply With Quote
Old 05-18-2011, 02:41 PM   #18
Both Knobs are on and I am to dumb to understand how to get one off
Rmcentyre is offline   Reply With Quote
Old 05-18-2011, 02:51 PM   #19
I did thread the bushing back on and indeed there is a poke hole in the bushing but I can't find the retainer anywhere on the spindle
Thanks for everyone's ideas but I am still stumped
Old 05-18-2011, 03:17 PM   #20
I am thinking the poke hole is only for a way to hook the bushing so you can thread it on and off without marking the bushing with a tool.
maybe SPS-1 was correct but I don't think I have the same Knob as he does
Old 05-18-2011, 08:15 PM   #21
fabrk8r
fabrk8r's Avatar
Once you get the hole lined up properly with the retainer and release the retainer using the proper diameter paper clip or wire you'll laugh at how easy it was to remove the knob.
I think you are really over thinking the process. Having said that, I have had a few of these types of handle-sets that were harder to remove than others due to the retainer or shaft being bunged up through abuse or old age.
BTW, the threads you see on the shaft are for the escutcheon plate, not the handle.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
Rmcentyre (05-19-2011)
Old 05-19-2011, 08:31 PM   #22
MY problem is I can't find the retainer.
and yes its old and I would bet banged up a bit as I have been pushing on the thing with a small metal punch. ( maybe the punch is to large??)
lack of visible vapor in steam shower installation CasaSemanas Plumbing 23 06-14-2017 03:05 PM
Metal Roof Screws Leaking WBNC Roofing/Siding 14 01-24-2010 03:50 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 08:54 PM
Stainless steel deck screws and hardibacker johnknez Building & Construction 1 10-09-2009 08:56 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
