Remove door knob - no screws visible ?
See photograph. There is a piece of spring wire under there that needs to be depressed. Indeed it can be a little tricky if you have not done it before. Might help to have a second person pulling on the knob (not too hard) while you try to press the spring. In this photo, the knob is fully released, I just have it sitting on the end of the post. I removed the faceplate for a better picture. I bought the set new, and they give you the "key" in the foreground to push the spring, but it is just a piece of flat steel, about 1mm x 2mm at the tip. Now that I look closer, either knob will come off this way, but the instructions say remove this one, because there are two screws that are accessed when mounting.
