Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-12-2011, 09:58 AM   #1
sweaty
Remove Cover From Broan Vent Fan
I have a Broan bathroom vent fan with a light. I need to remove the plastic cover to caulk the openings between the drywall. Cold air is coming in.
The plastic cover is held up by the metal light assembly. How do I get it off?
sweaty is offline   Reply With Quote
Old 11-12-2011, 10:10 AM   #2
Electrician
SD515's Avatar
Usually those grills are held up one of two ways. With spring clips…pull the grill down, squeeze the springs together and remove. Or remove the lens, then the bulb, and a screw or nut holds the grille to the metal housing/bracket behind it.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Ron6519 (11-12-2011)
Old 11-13-2011, 08:56 AM   #3
Caulking the grille cover is not a good idea. It needs to be removed periodically for cleaning and maintenance. If there is an attic space where the fan is, I would insulate/caulk up there.
Old 11-13-2011, 11:25 AM   #4
fill the gap between the fan and the drywall with foam or caulk to stop the air.
Oil furnace vent cover gone LindaLou2 HVAC 1 12-26-2010 05:45 AM
Old Vent fan cover for kitchen wall repairhelp Kitchen & Bath Remodeling 1 11-28-2010 08:54 PM
Can you remove hotwater vent stack? rhino1616 HVAC 1 03-11-2008 09:43 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
lead paint - remove or cover? teresa17603 Painting 8 10-26-2006 07:14 PM
