Relay Switch Question
Originally Posted by aalansari
I'm trying to use a relay to control an instrument that uses a 120VAC source. I need to control the relay (basically the coil) using a 5V signal. So it would have to be on a normally closed circuit and when I send the 5V signal it would break the circuit and turn the instrument off. So my question is, what relay would I need ? do I need to use 2 relays in series, as in a smaller relay to handle the 5V signal and and larger one with a higher contact rating for the 120VAC circuit?
I am limited to using whatever is available at radioshack...
Thanks,
Amir.
Relays  .. gotta dust off the cobwebs for that one. A regular single pole double throw with contacts rated at 115V ??A and coil rated for 5V?C ??A would work. Just wire the N.C. to the load. I think you will have a difficult time finding a relay with a 5 volt coil that isn't a circuit board mount.
An idea of the project would help. The way you have it described is the load would be re-energized whenever you lost the 5 Volts for whatever reason. I thought most stuff like that is done with solid state these days. Radio Shack has been pretty much a joke the last decade or so unless you wanted some high end audio or video stuff.
John Schaben
"Where all think alike, no one is thinking very much" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
