Regulating Output Current Of An Alternator - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-28-2010, 06:29 PM   #1
Regulating output current of an alternator
I live off grid and use solar to charge a large 24v battery bank for my electricity.
I have tried using 24v automotive alternators but cannot figure out how to limit the current of the alternator.
The battery bank is large so when the alternator kicks in there is a huge draw and it puts too much pressure on the belts. In the past this has resulted in the belts being thrown from the pulleys.
Is there a way to limit the current that the batteries will pull from the alternator?
Thanks for any help,
Bernn
bernn is offline   Reply With Quote
Old 12-28-2010, 07:17 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,590
Ayuh,... It sounds to me like the Battery Bank is in failure, or is discharged to a near Dead state...
Have the individual cells been Tested,..??
Alternators are design to maximum output, if, 'n when required...
If it's throwing it's belts, the belts, 'n pulleys are the suspects...
Bondo is online now   Reply With Quote
Old 12-31-2010, 06:29 AM   #3
hey man, what must I do if that happens? I am currently with that situation.
intropiles is offline   Reply With Quote
Old 12-31-2010, 10:18 AM   #4
Bondo's Avatar
Well,... Test the cells in the bank with a hygrometer, 'n load tester, replace any Bad cells, then charge per the cell's manufacturer's spec's...
Old 12-31-2010, 10:30 AM   #5
joed's Avatar
Rewards Points: 13,266
Replace the batteries. If one is bad and they were all bought at the same time, likely they are all close to the same state. 5 years is about the life of batteries we use in our UPSs.
Old 12-31-2010, 07:50 PM   #6
Rewards Points: 150
Inverter to transformer to rectifier then to batteries.
DC to AC to Transformer of desired voltage then back to DC to batteries.
DC cannot be transformed.
But i'd go and test all the batteries first like said above. Yeh, typical lifespan of UPS batteries are 5 years or so.
alecmcmahon is offline   Reply With Quote
Old 01-23-2011, 04:07 PM   #7
Could one of you guys post a block diagram of your system?
Dwoodsmith is offline   Reply With Quote
Tags
alternator , current , regulator
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Water pressure, gallon per minute values in relation to shower output JasonNY Plumbing 7 12-23-2010 05:50 PM
AFCI Breakers Keep Tripping mopowers Electrical 12 09-04-2009 03:11 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
