Refinishing Oak Floors - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 06:44 PM   #31
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
Personally....I think it looks great.....but you didn't follow my advice about the conditioner did you?
I would rub it down with steel wool if you want to soften up some of the spots.....it will also make for a really smooth surface....
Let me STRESS.....clean it well. If you use a water based sealer and there is any steel wool left....it will turn to rust....
Vacuum....wipe....vacuum again....wipe again....follow up with a tack cloth.....
If you used an oil stain and are going to use a water based varnish....wait about a week....if oil based varnish....you can do it now.
I would also suggest sanding with 400 grit paper after the first coat to knock down any spots....
And....clean well between coats....
Don't rush it....
Old 12-11-2011, 08:16 PM   #32
Rewards Points: 282
also, if using oil based finish (thats what i prefer), i usually thin it down 25 percent (3/4 poly, 1/4 mineral spirits)....it then goes on VERY thin, but easily allows the outgasing from the floor and the poly to occur without bubbles. will need more coats but really after the first coat, the rest are really fast.
in general, always thin everything that is oil based except stain, lol.
jcrack_corn is offline   Reply With Quote
The Following User Says Thank You to jcrack_corn For This Useful Post:
ddawg16 (12-11-2011)
Old 12-11-2011, 08:43 PM   #33
JOATMON
ddawg16's Avatar
That is really good advice.....I had bubbles from the first floor I did....now I know why.....
But to be honest....I did rush it a little....wife was in the hospital trying to hold off delivering our first son and I was trying to get the baby room done.....
Now you know why I say "Don't rush it"....
Old 12-12-2011, 05:40 AM   #34
the Musigician
DangerMouse's Avatar
I have to agree with those who like it. It looks far better than SOME refinishing jobs I've seen!
DM
Old 12-12-2011, 09:29 AM   #35
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Looks like it came out good! You are a patient man for doing the entire thing with an orbital sander. I used a drum sander in mine, I think we used 80 then 100 then 180 (or maybe it was 80, 120, 180 I can't remember) and then we hand rubbed it with 250 sponges before we tacked it. Luckily my buddy ran the drum sander as he had done it a few times before.
Anyways... I Had to do the stairs with the orbital sander as well as some of the closets since the drum was too big to fit - took just as long as doing the entire house w/ the drum.
CoconutPete is offline   Reply With Quote
Old 12-12-2011, 10:22 AM   #36
Crusty Old Dude
Big Stud's Avatar
Looks great to me. I like the way the more porous grain accents the wood in oak. You did a fine job,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
Old 12-12-2011, 03:09 PM   #37
I did a small bedroom a couple years back,, no rush, I use'ed a hand sander, starting with heavy grit and working up,, put a sealer down, was getting spotty,, when all said and done, it looks like the floor got a case of the spots, pretty sure it has red oak in it, at least it looks that way behind the radiator cover,, no way I'm posting pics of this affair. The only thing I can figure is I'll have to sand it down and then stain it to get rid of the spots, any advise would be apprieciated although I don't intisipate jumping into it for the time being,, maybe this is when I'm suppose to put down carpeting,, and OP,, nice job
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-19-2011, 05:56 AM   #38
Thanks for all the good comments. I had to rush this due to my brother was only hear in a weekend. The part I rushed as only letting the stain dry for 12 hours. I was told after by some on here and goggling that it will caused bubbles. You can't see them well on the pictures but they are small and there.
What I'm annoying about is the fact that I can't get the oil-based polyurethane smell to go away. I got three coats on but man it's been a week and the smell isn't any better.
Any advice?
management is offline   Reply With Quote
Old 12-19-2011, 02:49 PM   #39
Rewards Points: 282
Any advice?
yeah 12 hours isnt long enough...at least a day or two to get all the voc's out....for the bubbles, as mentioned, thinning the poly helps so that it will re-flow once the gases (and its OWN outgassing) pass through.
poly smell lasts about a week or two with decent ventilation so it should be gone soon...it is definitely a distinctive odor! At least its not as bad as oil paint.
Refinishing Painted Hardwood Floors Nivk Flooring 8 09-18-2011 06:16 AM
Refinishing Floors - Oddities somuchjackson Flooring 4 07-18-2011 07:22 PM
Refinishing Hardwood Floors When to have done bfan781 Flooring 2 12-05-2010 10:04 AM
Refinishing wood floors troyce1 Flooring 3 02-04-2009 01:11 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
