Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-10-2011, 09:17 AM   #16
A Little Of Everything
Refinishing Oak Floors
^ The different kind of sander is the key. Drum vss Random Orbital. It's the difference between a hand-held belt sander, and hand-held random orbital sander.
Another thing I really like about the RO Floor Sander (at least the ones I've rented) is that they have a bagging system that leaves virtually no dust behind.
DrHicks is offline   Reply With Quote
Old 12-10-2011, 12:14 PM   #17
This RO Floor Sander doesn't pick up any dust at all. It doesn't go airborne just left all on the floor. Only a little dust in the bag. I used my dust vac instead of the bag and same result.
It does the job though.
management is offline   Reply With Quote
Old 12-10-2011, 02:15 PM   #18
How long does the stain before the poly have to sit before applying the poly?
Old 12-10-2011, 02:21 PM   #19
Tileguy
Bud Cline's Avatar
Until it is dry.
Old 12-10-2011, 02:29 PM   #20
You must be using an entirely different kind than the ones I've used. The ones I've used have a vacuum and bag right on the machine.
Old 12-10-2011, 02:34 PM   #21
There is on directly on it but it's sucked. You can take it off and and use a dust vac.
Old 12-10-2011, 02:38 PM   #22
That's what it's supposed to do!
Actually, I don't know what to tell you. On the machines I've used, the vacuum worked great. The sander left virtually NO dust anywhere.
Old 12-10-2011, 06:25 PM   #23
JOATMON
ddawg16's Avatar
Same for me....and it was a rental from HD....
As for the stain...if you use an oil stain and want to cover it with a water based latex clear coat...you need to wait at least a week....
Oil based clear over oil stain? Couple of days....us woodworking guys have the same issue....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 12-11-2011, 04:47 AM   #24
Ok so I got the stain down. The grain really is showing very strong. Any reason why that is? Is it the stain choice?
Refinishing Oak Floors-image-2007660583.jpg   Refinishing Oak Floors-image-2795626661.jpg
Old 12-11-2011, 07:47 AM   #25
Looks like you used pretty dark stain.
This is an oak floor of a rental house bedroom I refinished a couple years ago. I used what was called "natural" stain. I liked the warm feel it gave the wood.
Old 12-11-2011, 08:29 AM   #26
Didn't think it would be that dark but yeah. Gonna change the wall color though. It came like that with the house.
Old 12-11-2011, 08:46 AM   #27
Looks like you probably used a "dark oak" stain. Not too much you can do about it now. If it were me, I'd go no glossier than "satin" for the poly. "Semi-gloss" or "gloss" give it a little harsher look, in my opinion.
The right color paint will really make those rooms look nice!
Old 12-11-2011, 09:14 AM   #28
Just saying,, on the poly, the strength is in the degree of gloss,, was told to go high gloss first two coats, then use satin for top coat if I wanted to tone down the shine.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-11-2011, 05:23 PM   #29
did you put a sealer on before the stain?
sanding sealers tend to even out the stain and give you MUCH greater control over the shade (ie, if you put stain on unsealed wood, it will soak it up pretty instantly, if it has a sealer on it you have time to wipe off excess and coat to color/use multiple coats to get desired shade).
jcrack_corn is offline   Reply With Quote
Old 12-11-2011, 05:37 PM   #30
Ironlight's Avatar
That looks like a nice old red oak with winter wood and dark grain. Tends to stain out that way in my experience and I for one love it.
As for how long to let the stain dry, 24 hours at room temperature and 50% humidity will do it, provided you have wiped it down good, but it looks like we're past that marker.
Great job. Lookin' good!
Ironlight is offline   Reply With Quote
The Following User Says Thank You to Ironlight For This Useful Post:
DUDE! (12-12-2011)
Refinishing Painted Hardwood Floors Nivk Flooring 8 09-18-2011 07:16 AM
Refinishing Floors - Oddities somuchjackson Flooring 4 07-18-2011 08:22 PM
Refinishing Hardwood Floors When to have done bfan781 Flooring 2 12-05-2010 11:04 AM
Refinishing wood floors troyce1 Flooring 3 02-04-2009 02:11 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
