Refinish Painted Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-28-2009, 01:08 PM   #1
Refinish painted drywall
I have added new drywall to a single wall in my living room. The ceiling and right-hand wall were previously textured and painted (and there is some mortar from the wall I replaced, which was covered in faux rock). I have been trying to smooth the texture and paint by multiple means, but the paint is very tough. I have tried 60 grit sandpaper and sponge, a rotary sander, and a paint scraper, but progress is limited. I am afraid to try paint thinner or stripper for fear of destroying the drywall underneath.
I have it to a certain smoothness now, but I am sure the tape will not be smooth if I apply it. I was thinking I could put a smooth, thin layer of mud on the wall with the 12" knife and, after the mud dries, apply the tape on top as if it were fresh drywall. Would there be any issues with this?
Thanks for your help!
broadbear is offline   Reply With Quote
Old 03-29-2009, 01:48 PM   #2
Registered User
Rewards Points: 4,924
Hi, broadbear. You need to remove all the mortar, unless you later put a very heavy texture on that area. A power sander and 60 grit paper would remove paint and texture very fast, unless you're talking about the grout. If so, I would use a wide-bladed chisel to remove it. The chisel has 2 sides to the blade, try each for best performance.
Where the tape goes has to be sanded below the rest, so when you add 3 coats of compound there, it won't be much higher than around it.
Here is a patching plaster site: look for paper tape application. http://www.plaster-wall-ceiling-solu...questions.html
The layer under the tape has to wet when tape is applied. Be safe, GBAR
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
patching painted drywall newb question afabco Drywall & Plaster 2 11-12-2008 07:58 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
Can you glue drywall to painted conrete block pillars? yummy mummy Building & Construction 30 03-11-2008 09:26 PM
