Redoing Exterior Of House...tips?!? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-13-2014, 04:05 PM   #1
Rewards Points: 160
Redoing exterior of house...tips?!?
I am redoing the exterior of my house and looking for best ideas...I'm getting new windows and siding but was wondering about a few things.
I want to install 2" foam for R value and typar (wrap) the house....is the foam installed first against the house and then typar it or typar first?
Also I want to "soundproof" as we have a real noisy street and I want to eliminate some of the sound I hear....
I've heard of some people using a product that adsorbs heat...not sure if that is a good idea
Most likely going with vinyl siding or hardiboard
Thanks for your info
hellothere123 is offline   Reply With Quote
Old 01-13-2014, 09:00 PM   #2
Rewards Points: 216
there is a current thread here about exterior xps(foam). it is not a good idea. 1" is better.
ROXUL in the walls will kill a lot of noise.
hardiboard, as it is more dense will kill more noise.
Fix'n it is offline   Reply With Quote
Old 01-13-2014, 10:27 PM   #3
Registered User
Rewards Points: 5,188
If you go Hardie, your code requires a rainscreen; http://www.mtcc1170.com/images/BCRainScreen.pdf
Where in Canada, 2" would be minimum in most places?
Under FB or over; http://www.buildingscience.com/docum...ting-sheathing
http://www.buildingscience.com/docum...d-wall-systems
Gary
Gary in WA is online now   Reply With Quote
Old 01-14-2014, 04:26 PM   #4
Rewards Points: 160
I couldnt find the thread on exterior faoom being a bad idea...cant see why it would be a bad idea?
Roxul in walls - are youu saying opening exterior walls - rmove batt insulation and install roxul? I'm not sure what you mean....the inside of the house is done...
Old 01-14-2014, 04:31 PM   #5
Rewards Points: 336
You won't have much luck increasing the sound isolation from exterior to interior unless you do two things:
1. Get insulated double-hung windows.
2. Build the interior walls using deep studs, multiple layers of gypsum board , and resilient isolation clips.
If you're not touching the interior, you won't be able to make any meaningful change in sound isolation.
JKeefe is offline   Reply With Quote
Old 01-14-2014, 09:33 PM   #6
Rewards Points: 216
i'm not saying exterior foam is bad. i am actually going to do it myself. i was saying , that those here, are saying that 2" is bad.
roxul is much more dense than FG. so it deadens sound better. but your inside walls are done, and so is this idea.
Old 01-14-2014, 10:30 PM   #7
Rewards Points: 216
here is the thread. my "bad" rating was a bit overboard.
2" foamboard insulation before siding
Old 01-14-2014, 10:35 PM   #8
Rewards Points: 13,228
I guess it could be done but I just can no imagine having to do a whole house with 2" foam.
#1, It's over $30.00 a sheet plus the cost of the tape. http://www.homedepot.com/p/Owens-Cor...45W/100320352#
#2, All the windows and doors are going to be effected. To do it right the windows would have to be pulled and redone or there going to be recessed.
Old 01-16-2014, 09:18 PM   #9
Registered User
You could leave the windows recessed (innie) or move them out (outie-pp. 1-10). If thicker than 2" FB, the window may not get enough room air circulation and have condensation wetting problems inside.... pp. 10+ for "innie"; http://www.google.com/url?sa=t&rct=j...Br40fQ&cad=rja Though you would want to detail a new WRB and window rough opening wrap flashing... require resetting window anyway. Any vapor barrier poly at drywall?
Isn't Canada Code 1-1/2" thick, minimum?
Gary
Weird wiring in house fdmillion Electrical 13 06-14-2013 07:49 PM
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
Considering buying a house that needs regrading HELP Dr.JUSC Landscaping & Lawn Care 9 06-16-2011 11:58 AM
New pool house with new toilet - tips wanted kandrewp Plumbing 3 07-28-2010 09:47 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
