Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-29-2011, 11:34 PM   #1
Question
Redoing brick on fireplace
Looking for advise/tips
I have unpainted brick around a wood fireplace. I've purchased the brick, Eldorado Stone and they said to use Type S Mortar.
I was told since the brick is unpainted that I can directly apply the bricks with mortar to the existing fireplace.
I have also heard from others that it is better to first put on a scratch coat and then apply the new brick.
Also told to attach "chicken wire" so the motar will adhere better.
Any expeience/best practises?
hellothere123 is offline   Reply With Quote
Can you seal brick on fireplace? mrs1885 Remodeling 3 03-29-2011 11:52 AM
Drywall a Brick Fireplace schw1927 General Discussion 1 01-26-2011 04:12 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Brick Fireplace Paint ... g8master Building & Construction 3 12-20-2009 01:31 PM
