Red Devil-Create-a-color-caulk ?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 02:05 PM   #1
This is a fairly new product that allows you to custom mix caulking compound to any color. I'm wondering if it would be suitable for caulking a shower with dusty rose tile/grout. It needs caulking as well as grout and I've been using clear silicon for tub/tile But clear seems to only last about a year and then you can see dark spots of mold behind it. Even when it's new, it still doesn't look great. I would much prefer doing it in the same kind of color as everything else.
So, has anybody tried it, does it work and would it work for a shower application? I sent emails to reddevil.com but no reply.
Link: http://www.reddevil.com/products.cfm?c=cs&cat=1
Description
A patent pending, premium quality caulk developed specially for use with Create A Color Caulk Mixers, to achieve an exact color match by adding paint to the caulk.
Key Features
Excellent Adhesion
Easy Mixing w/ Create A Color Mixers
Excellent Color Match @ 24 hrs Drying
Water Clean Up
Low Odor
40 Year Durability Caulk
VOC Compliant
Uses
For use anywhere around the home where an exact color match to a paint color is required. Adheres to most common construction substrates
ROB M is offline   Reply With Quote
Old 10-23-2008, 07:54 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Description
Key Features
Excellent Adhesion
Water Clean Up
Low Odor
VOC Compliant
Uses
I would call them and talk to there technical support about a wet area application. Let us know what you find out:
Red Devil, Inc.
4175 Webb Street
Pryor, OK 74361
Toll Free: 1-800-4A-DEVIL (1-800-423-3845 select option 1)
Phone: (918) 825-5744
Fax: (918) 825-5761
info@reddevil.com
Jamie
jamiedolan is offline   Reply With Quote
Old 10-23-2008, 09:22 PM   #3
Registered User
Termite's Avatar
I seriously doubt that it would be a good idea in a shower where constant moisture and mold/mildew are issues.
Tile stores have sanded and unsanded caulk to match just about any color of grout made. Sometimes box stores have a few colors but tile suppliers typically have an excellent selection. These caulks are shower-appropriate.
Create Window in Master bathroom bladesj Carpentry 2 08-12-2008 09:43 PM
I want to create a compost area. flashme18 Landscaping & Lawn Care 2 07-07-2008 09:59 AM
What router bit is used to create the inside angle on a window stool? Mikedks Building & Construction 7 05-12-2008 04:43 PM
