Recessed Nitch Depth Along Bathroom Wall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 06:39 PM   #1
Rewards Points: 1,634
Recessed nitch depth along bathroom wall
In the middle of remodeling a bathroom, two sides of the shower area are surrounded by interior walls - wood framed 2x4 studs.
Thinking of framing in a few recessed nitches on that wall for sponges, shampoo, body wash etc...HOWEVER...the wall is only 3.5" thick (2x4).
The other side of the wall is a hallway, so I will have sheetrock covering the back side of that wall. The front side of the wall will have a 1/2" cement board over the wood framed wall, then 1/4" wall tiles, which makes the maximum depth of that nitch 3.5" + 0.5" + 0.25" = 4.25" measuring from the back of the sheetrock from the other side.
I don't think I can just tile over the back of that sheetrock (after waterproofing) can I? I assume I need a piece of cement board on the back side as well? Plus the tile over it. That reduces the depth to 3.5" again.
Is 3.5" enough for a shower nitch? Seems awfully shallow...should I just forget it?
miamicuse is offline   Reply With Quote
Old 03-07-2013, 06:52 PM   #2
Rewards Points: 34
3 1/2 inches is fine. You can either make the niche or buy pre fabbed ones. Measure the stuff you would be sticking in the niche just to be sure you have enough height.
djlandkpl is offline   Reply With Quote
Finishing Basement - Bathroom Wall Placement DCTepper Plumbing 3 04-20-2012 06:31 AM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 01:58 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Framing Shower Wall in Bathroom Justin LaRue Kitchen & Bath Remodeling 2 06-30-2009 10:34 PM
bathroom wall advice bigbrad123 General DIY Discussions 9 06-07-2006 07:26 AM
