Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-22-2010, 03:41 PM   #1
Lightbulb
Recessed Lighting Baffle Question
Does anyone know whether a 6" Airtight Baffle Cone be changed out one-for-one with typical 6" recessed lighting baffles? I have a 16 year old home with original recessed lighting located below attic space. I am hoping to stop the heat and ac loss into my attic by replacing just the baffle if possible, rather than the complete housing. Thanks!
CarolinaW is offline   Reply With Quote
Old 08-22-2010, 08:30 PM   #2
You would need to remove the current housings and replace them with air tight housings you could cover with insulation. Just realize you will have to put a lower wattage bulb in these. This could mean the need for additional units for enough light in the space.
Ron
Cover for Recessed Lighting Trim Model HBR635(T49) aghahary Electrical 4 07-23-2010 05:30 PM
Seal Gap Between Drywall Ceiling and Recessed Lighting Can albasaurus Electrical 8 07-10-2010 08:27 AM
Recessed lighting for 15 amp circuit jacads Electrical 5 03-12-2009 01:12 PM
Recessed Lighting tyreal78 Electrical 6 02-21-2009 11:06 PM
Recessed lighting in billiard room? kcrossley2 Electrical 11 01-11-2009 09:00 AM
