Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-24-2010, 06:21 PM   #1
Re-hang/frame a door in with a brick surrond
Hello all!
So, I live in a self managed condo building and I like to DIY most of the repairs for the building, but this latest one is stumbling me a bit.
The door to our building opens outward, is a heavy steel door, and the hinges are pulling out of the wood.
I tried to use longer screws to attach the hinges into the stud.... then found out there is no stud on the otherside. Its Brick!
So, how should I proceed to re-hang this door? I would like to keep the same frame and door-- although it looks really ugly it is strong and functions fine.
Thanks!
DIY.Condo is offline   Reply With Quote
Old 10-25-2010, 06:47 AM   #2
Use tapcon screws into the brick.
Tags
hang door brick
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Run wire to Breezeway through brick and up brick wall wad2k Electrical 0 04-16-2010 09:18 AM
Reusing old brick for a shop bigalpha Building & Construction 12 01-20-2010 08:59 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Sealing historic brick tenzo General Discussion 2 11-22-2008 04:04 PM
