Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-18-2011, 02:38 PM   #16
Tileguy
Bud Cline's Avatar
Re-grouting tile kitchen counter top
So I'm pretty sure it is literally caulk between most of the grout joints, but I have read (even in the above post) of the silicon caulk sealers (or epoxy sealers).
OK, I'm going to repeat myself here: "If the grout (joints) have been filled with 100% silicone (caulk) it won't be easy to get rid of totally. You can use a caulk remover but you will never remove it from the microscopic pores of the existing grout."
THEREFORE: It isn't very likely a grout stain is going to produce acceptable uniform results.
tile around kitchen island and around kick plates cmlcsu Flooring 4 01-08-2012 11:35 PM
Two Questions about Kitchen Wall Tile sbazzle Kitchen & Bath Remodeling 15 04-23-2010 09:59 AM
Kitchen - tile backsplash grout Museseek Tiling, ceramics, marble 3 03-14-2010 01:52 PM
Kitchen tile install - need advice on the best "wrong" way to do it! kiddo19 Flooring 11 03-21-2009 02:30 PM
Replacing kitchen countertop tile budget consciou Remodeling 5 03-17-2009 10:24 AM
