Re-caulked The Tub. It All Peeled Off By End Of Shower. Cure Time? Bad Caulk? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-28-2013, 03:50 PM   #1
Rewards Points: 129
Re-caulked the tub. It all peeled off by end of shower. Cure time? Bad caulk?
I re-caulked my tub with a tube of DAP Kwik seal.
Did it on Sat afternoon.
The next morning, I showered, and it will bubbled and started to peel.
I scraped it all off with a towel, since it was so soft.
I guess I only waited about 18 hours.
When I redo it, how long should I wait before taking a shower?
I used this:
http://www.dap.com/product_details.a...=22&SubcatID=5
Mathlete is offline   Reply With Quote
Old 10-28-2013, 04:17 PM   #2
Rewards Points: 268
I had that happen too. The next time around I used some Red Devil kitchen and bath caulk that advertised 1 hr til it could get wet (I waited 8 hrs anyway, worked fine).
Most important thing I found for adhesion was to use some alcohol wipes to clean the surfaces where the caulk would adhere to.
Of course, time, temp, humidity all come in to play for curing time.
This is just based on my experience, I'm sure there are better products out there. I just needed it to be ready fast for the wife and kids (it's our only shower).
Good luck!
Marqed97 is offline   Reply With Quote
Old 10-28-2013, 04:46 PM   #3
Rewards Points: 5,974
I have used the Dap with no problems I suspect something in the corner such a a silicone residue or some soap scum or something.
Old 10-28-2013, 04:46 PM   #4
Rewards Points: 13,458
To do it right all the old caulking need to go.
It needed to be perfectly clean and dry.
You fill the tub 1/2 up and only use silicone caulking with a mildicide in it.
Wait 24 hours and drain the tub.
Kwic seal is useless.
If the wall at the bottom is molded or the tiles are loose (if there's tile) most likely your wasting your time. There's possible moisture damage behind the wall.
Old 10-28-2013, 04:48 PM   #5
Rewards Points: 129
Can you post a better product to use?
Old 10-28-2013, 04:54 PM   #6
http://www.homedepot.com/p/GE-Silico...5#.Um7crBPD_IU
Also comes in colors and caulking gun sized tubes.
Old 10-28-2013, 04:55 PM   #7
Rewards Points: 129
Thanks!
Old 10-29-2013, 05:55 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,184
+1 to Joe's feedback.
Most caulking issues are surface prep related.
Old 11-05-2013, 07:29 PM   #9
Rewards Points: 129
Redid this with the same DAP. This time, I waited 2 days.
On the 3rd day, I saran wrapped the caulk on the tub edge, and took a fast shower.
It seems to have held.
Old 08-03-2014, 12:26 PM   #10
Rewards Points: 129
The Kwik Seal has melted off yet again.
Not even 1 year. Junk.
This is getting very annoying.
Is this product just not legit for SHOWER caulk?
This time, I got a hard tube of DAP 100% Silicone caulk.
Old 08-03-2014, 12:40 PM   #11
The GE Kitchen and Bath specific caulking has worked well for me in the past.
Old 08-03-2014, 01:32 PM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
I second the GE Silicon Bath and Kitchen but I do not like it in a squeeze tube. Too hard to get a good bead. Buy in in a regular caulk tube and use a caulking gun.
And I also think the DAP product you used is not suitable for your application.
Coastal South Carolina
Old 08-03-2014, 02:05 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The caulk products are not your problem.
Your walls have moisture inside of them and that is your problem.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Windows on Wash (08-03-2014)
Old 08-04-2014, 10:47 AM   #14
Rewards Points: 129
This was the OLD
This is the NEW:
http://www.dap.com/product_details.a...94&SubcatID=26
I will keep you updated.
Old 08-04-2014, 10:48 AM   #15
Rewards Points: 129
How do I address moisture in the walls ?
Curing Caulk in Shower Stall aprilskitchen Flooring 3 01-03-2012 05:50 AM
shower door caulk Neil Bean Kitchen & Bath Remodeling 1 12-04-2011 10:50 AM
Shower Door Caulk boomer7 General DIY Discussions 20 10-20-2011 07:25 AM
Where to caulk in a newly tiled shower CrossWorks Flooring 5 05-05-2008 11:07 PM
MVP4 cure time... kemerick Flooring 1 12-15-2007 12:50 PM
