Raynor Garage Door Opener - Stuck - Please Help! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-30-2008, 11:36 PM   #1
I have a 1/2 HP Raynor Garage Door opener that is stuck. When I plug it in, the motor immediately tries to "shut" the door, although it's already shut. There are no sensor eyes (too old) so that's not the issue. It's almost like the sensor that tells the motor the door is shut is defective. I've pulled the red rope and disengaged the door from the chain. The door moves freely, but the motor still is trying to "shut" the door. When I tried to re-engage the door, I could not get the arm to reconnect. It's as if the plate that it connects to is too far forward and can't be reached. I'm ready to call someone to repair it, but I wanted to check on here first.
Is there anything I can do to fix/troubleshoot? Thanks in advance!
donfan23 is offline   Reply With Quote
Old 10-01-2008, 07:28 AM   #2
Without knowing the age of the opener it's tuff to trouble-shoot.
The door opener should fail running in the open direction, not down. Down only tells me that a relay's welded shut, probably due to a power spike or old age. Again, this is commont to all brands and a best guess from the info you provided. If this is the case then you need a new circuit board. Nothing you can do with the existing relay to correct it.
I'd call a repair guy. Shop around for someone that's familiar with your brand and be prepared to buy a new one if yours is old. Spare parts are not always available.
DIY openers are available starting at $125
Shamus
Shamus is offline   Reply With Quote
Old 10-01-2008, 08:34 AM   #3
Thanks Shamus. I messed around with it some more last night. I was able to reconnect the arm and get the door to open by turning the large wheel on the opener (that's connected to the motor via a belt). When I plugged in the opener, it shut the door, but then kept trying to run. The opener is 20+ years old. Make me wonder if it's worth repairing or if I should just buy a new one.
Tags
garage door opener
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 06:31 PM
drain stuck how to remove tverhoef Plumbing 1 03-14-2008 06:53 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
Stuck Windows on 3rd floor GooperMC General DIY Discussions 8 07-19-2007 09:35 PM
