Rawlbolt Drilling Sizes Guide - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-01-2007, 11:42 AM   #1
Rawlbolt drilling sizes guide
Hi! I'm a newcomer here! Hello all! Can anybody help me? I need some form of guidance re. hole-drilling sizes for metric sized rawlbolts & hooks.
Eg: 8mm rawlbolt - ?? mm drill
Thanks!
lorbon is offline   Reply With Quote
Old 03-01-2007, 06:45 PM   #2
joed's Avatar
Rewards Points: 11,590
I'm not sure what you want. If you have a 8mm bolt you need an 8mm hole.
If you are looking to tap a thread in hole for an 8mm bolt then you need a tap drill size which is 17/64 for m8-1.25 or J for an m8-1.0.
Old 03-04-2007, 01:30 PM   #3
Re Driling sizes for rawlbolts
What I mean is what size should I drill the hole to take the anchor shield which is usually bigger than the bolt-size itself.
For instance an 8mm bolt might have a 13mm diameter anchor shield.
Old 11-22-2010, 04:30 AM   #4
Hi there,
There are two ways to do this...
One: Measure the outside diameter of the shield.
Eg. 8mm Bolt has a 14mm shield. So use a 14mm concrete drill.
Two: Read this blogpost for a list of all the required Rawlbolt drill sizes. Industrial Supply News
Notes:
1. Make sure you drill the substrate the correct length, the shield should fit from the collar to the bottom nut. If you drill the hole to short the shield will pull out. If you drill too deep, you loose the strength value as the shield looses pieces in the hole.
2. Check the type of substrate you are drilling, in soft material when you drill the 14mm you could loose some substrate making your hole as much as 16mm. Harder materials obviously will loose less substrate.
Hope this helps!
Alistair is offline   Reply With Quote
Old 11-22-2010, 08:45 AM   #5
joed's Avatar
This post is 3 1/2 years old. It hink it has been resolved by now.
Old 11-22-2010, 10:54 AM   #6
Rewards Points: 1,002
And if not
http://www.rawlplug.co.za/PDF/PAGE_4...OSE%20BOLT.PDF
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Alistair (11-23-2010)
Old 11-23-2010, 02:16 AM   #7
Hi Joed & Anti-Wingnut,
Fortunately for us all, RAWL have not changed the drill sizes of their sheild anchors over the past three years.
Thank Goodness.
Thanks for posting the table.
The end result of our efforts guys, is that the post is now both relevant and correct in terms of the information given.
BONUS!
Old 10-09-2011, 09:07 AM   #8
Hi,
Bit of a newb here but came across this on google while looking for instructions on installing rawl bolts.
I have a M8 60x8mm bolt with rawl shields.
It said in the instruction manuals of a bracket I am installing to drill a hole 10mm in size.
I did this but the shields don't fit in at all.
Any idea what size of a drill is required? I do not understand that table at all!
The thickest part of the shield seems to be around 14-15mm in diameter, but I am not sure if that is supposed to be sticking slightly out of the wall or not.
rubbed is offline   Reply With Quote
Old 10-09-2011, 08:50 PM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
take another look at the chart. If you are looking for the hole size for the shield itself, then you want the hole diameter for the substrate. for M8 it is 14mm
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Seeking newbie guide to carpentry neophase Carpentry 2 05-13-2006 08:28 PM
