Raising Fiberglass Porch Column - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 08:31 AM   #1
I'm building a covered front porch. I found a contractor who is selling some new Permacast fiberglass porch columns at a substantial discount then new. The problem is they are only seven feet in height. I need columns at least 7'6".
Can I compensate for the the 6" by adding an additional base "block(?)" for the column to rest on? Basically, taking something like a cedar or PT 6x6 and picture framing it into a base for the post to rest on? I don't think the additional base will have any effect on the load bearing of the column, but may have possible issues with the anchoring?
I've searched the web and have not found any topics to raising a porch column this way.
xk49 is offline   Reply With Quote
Old 08-01-2011, 09:52 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 582
You shouldn't have any problems doing that if you make sure the base can drain water well instead of holding water. One thing you could do if you wanted to is make the capital 2 -1/2 inches thick to take up some of the room so the base wouldn't look so heavy. Just make sure if you use wood for the base to take water drainage into consideration.
Check out these fiberglass base and capitals that you may want to take a look at.
http://www.crowncolumn.com/homeowner...italsbases.php
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-01-2011, 10:11 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Would you happen to have a drawing or pic (if its been started)?
12penny is offline   Reply With Quote
Porch column base rotted RickO General DIY Discussions 17 10-25-2011 08:43 PM
Removal of Porch Column sjsdesigns Building & Construction 4 04-12-2010 07:48 PM
Replacing Porch Column base, what wood to use? Shamus Building & Construction 7 05-31-2008 12:29 PM
Installing a structural fiberglass column Weekend Warrior DIY Building & Construction 9 11-19-2007 12:33 PM
Raising floor/tile porch subfloor unhandy andy Flooring 2 09-04-2007 10:05 PM
