Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-20-2008, 11:43 PM   #1
raised patio
We took out our pool 2 summers ago and back filled the area. Now we want to put a patio in. The problem is the area for the patio is below grade. We will have to raise the grade around the patio when complete. My question is when we put down the base of crushed stone (4 inches) how do I get it to pack down and hold on the edges. Someone suggested building a form from CCA lumber since the patio is square. Any suggestions?? This is a new venture for us as "do it yourselfers". We are planning to lay pavers.
svt4444 is offline   Reply With Quote
Old 04-21-2008, 08:11 AM   #2
Master General ReEngineer
Bondo's Avatar
raised patio
Ayuh,....
Just build the Stone Pad slightly Larger than is necessary,+ add some backfill dirt to support the edges.....
Old 04-21-2008, 09:23 AM   #3
concretemasonry's Avatar
raised patio
Make sure your slab is well reinforced. The filled in pool is not compacted and will continue to settle (2 years of sitting does not creally compact the soil.
Compactin 4" of base will not make up for the settlement below.
concretemasonry is online now   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Concrete Form for Raised Patio PerpetuallyRepairing Building & Construction 6 04-08-2008 07:33 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 02:30 PM
