Raised Floorboards Under Carpet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-16-2011, 11:15 AM   #1
2 story house:
Recently I've been noticing a slight "dip" (.5 inches) every 2 to 4 feet or so in my upstairs hallway. It seems as though it occurs where the floorboards should be nailed down to the joists, but I'm not sure. I also have this problem in an upstairs closet where I was able to pull up the carpet and confirm that all of a sudden the floorboard raises .5 inches.
What's the cause of this and how can it be remedied?
Gerard
gerardswork is offline   Reply With Quote
Old 12-16-2011, 12:03 PM   #2
Rewards Points: 5,336
If the finished floor is separating from the substrate, it either wasn't nailed or glued properly.
If it's a floating floor, it was put down without a space around the perimeter and the floor is buckleing because of it. It's expanding against the wall and lifting in the middle.
Do you know what kind of floor you have or who put it in?
Ron
B. Franklin 1759
Old 12-16-2011, 12:53 PM   #3
Thanks for the response. It is simply plywood laid on floor joists. I'm not sure who laid the flooring, but would say that it is butting up against one another. The house was built in the 1980's with nails, not screws, and there are many squeaks on the 2nd floor that I've fixed with screws. I'm wondering if I can't screw down the floor boards where its butting.
Any other thoughts or suggestions?
Old 12-16-2011, 01:05 PM   #4
Are you calling"floor boards", plywood? So you basically just have a subfloor down?
If it's just the plywood lifting, you can screw it down to the joists.
If the plywood is square edged, there should have been a 1/8" space between the sheets for expansion.
Ron
B. Franklin 1759
Old 12-16-2011, 01:57 PM   #5
Thanks...I'll let you know how it turns out...is this something of concern or a typical problem?
Old 12-16-2011, 02:14 PM   #6
It's an issue that you should not have. The people who built the house took shortcuts. The plywood should have been T&G, spaced properly, glued to the joists and nailed down.
It's more of an annoyance and I probably wouldn't plan on tile or hardwood flooring with this issue. As part of the remediation, I'd cut along the plywood seams to introduce the needed space between the sheets. This would relieve the lateral pressure on the joints.
Just cut the depth of the plywood.
Ron
B. Franklin 1759
Old 12-17-2011, 09:57 PM   #7
Rewards Points: 1,092
A dip? Any chance the plywood is too thin for the span? What thickness, and what span?
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 09:20 AM
bubble under carpet after water spill - fixing psittacus Flooring 4 03-06-2009 01:23 AM
joining floorboards to carpet cheech Flooring 8 02-23-2009 04:04 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
