Radon Test Results - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-19-2007, 01:38 AM   #1
Rewards Points: 1,088
Radon Test Results
I had a radon test performed on a house I have under contract, and it was measured to be 8 pCi/l, which is above the passing level of 4 or below. Is anyone familiar with remediation options? I heard that some sort of external fan can be added by a professional radon remediation company, and this external setup is better than an internal one that can cause a lot of potential mold due to condensation.
There is an existing pvc tube right above the sump pit, but it is currently not connected to the sump pit. I heard from a radon tech that this is generally a cursory add on to the sump pit that really does not do much, in that an active, not passive, measure is the best solution.
handy man88 is offline   Reply With Quote
Old 11-20-2007, 12:03 PM   #2
Hi,
We install almost all interior radon systems. I have never seen any condensation problems on the outside of the pipe system to be concerned about. The pipe may become a little damp to touch in the middle of summer but not dripping water. Outside system are much harder on the fan life and uglier IMO.
If that pipe above the sump may be there for a passive system. But it would have to 3" or 4" PVC and run straight up through the roof to be of any value. A passive system can reduce levels by about 30%.
If you have a draintile system in place an active system should bring the level down well below 2pCi/L.
You can read more about systems here if you like...
http://www.indoor-air-health-advisor...itigation.html
Radonguy is offline   Reply With Quote
Old 11-20-2007, 03:24 PM   #3
Originally Posted by Radonguy View Post
Hi,
Thanks, results came back with < 1 pCi/L. But, I think I may have to get the contractor back out b/c when the sump fills during a rainstorm, the radon tube tries to suck water before the sump kicks in. Contractor might have to trim a bit off the tube.
Old 11-20-2007, 04:49 PM   #4
Or lower the float on the sump pump.
Radon Test! handy man88 Plumbing 2 10-18-2007 07:38 PM
Please describe exactly side sewer TEST wannabuild Plumbing 2 02-14-2007 07:44 AM
Leak Test w/compressed air hennyh HVAC 2 11-27-2006 04:36 PM
