Radon Mitigation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-03-2008, 06:22 PM   #1
Radon mitigation
Hello Everyone!
I am just checking to see if anyone has any experience with Radon gas problems and/ or its mitigation?
I did one of those 72 hr home tests and the results came back at 5.2pCi/L. The EPA says anything over 4.0 pCi/L should be remedied. Any thoughts or suggestions?
Thanks in advance!
DIY4EVER
DIY4EVER is offline   Reply With Quote
Old 03-03-2008, 06:52 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Simple Answer: Sounds like you should start calling around to get quotes on installing a radon gas mitigation system.
Also, if you have well water, you would want to get that tested for radon too.
- Build Well -
Old 03-07-2008, 11:02 AM   #3
I can provide some DIY Radon Mitigation help. Includes some materials and tech support.
http://www.indoor-air-health-advisor...itigation.html
Radonguy is offline   Reply With Quote
Old 08-20-2008, 08:43 PM   #4
install an in-line radon fan
Hi,
The best solution, I came across, to mitigate high levels of radon is to use an in-line radon fan.
I have reduced the level of radon from 15 pCi/L (maximum acceptable in USA is 2 pCi/L) to 0.4 pCi/L by using this type of system.
I have took steps to measure the radon levels only after a friend has been diagnosed with an early form of lung sarcoma (cancer) - he had 21 pCi/L in his basement home office.
You can get additional information about radon mitigation and risks at
http://handyowner.com/2008/08/17/ins...gation-system/
http://handyowner.com/2008/08/15/rad...y-killing-you/
Cheers!
njmaan is offline   Reply With Quote
d.i.y. radon mitigation? smallcrpt HVAC 12 07-01-2015 01:18 PM
Does Drylock waterproofing help reduce radon? nuadhu1 Remodeling 1 02-10-2008 06:47 AM
Radon Test Results handy man88 General DIY Discussions 3 11-20-2007 04:49 PM
Radon Test! handy man88 Plumbing 2 10-18-2007 07:38 PM
