Radiator Shelves - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-17-2012, 01:29 AM   #1
A Little Of Everything
Rewards Points: 1,364
Radiator Shelves
Our daughter & son-in-law just bought a cool little tudor craftsman house with radiator heat. Everything works great, but we're all kicking around ideas...
We'd like to "mount" a 1x12 atop the radiators in order to have some shelf space, etc. Not really wanting to do the full cover, but just a shelf. And I'd prefer to not have the 1x12 sitting directly atop the radiator.
Does anybody know of any brackets for such a project, or is my best bet to just make some myself?
Thanks for the ideas! Below is a picture of one of the radiators.
DrHicks is offline   Reply With Quote
Old 12-17-2012, 08:18 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
I would be concerned about reducing the effectiveness of the radiator. They circulate air by creating a flow of heated air straight up.
PoleCat is offline   Reply With Quote
Old 12-17-2012, 08:28 AM   #3
Rewards Points: 13,300
A 1 X 12 sitting over the top of all that heat would curl up like a banana.
One thing you could do is remove the casing on the windows, remove the stool and replace it with a wider one. You can buy stock stool up to 5-1/2" wide.
It would be a good time to add insulation around those windows.
tylernt (12-17-2012)
Old 12-17-2012, 09:10 AM   #4
Rewards Points: 226
perhaps a glass shelf would work.
gosh. i sure hope you don't paint that nice wood.
Fix'n it is online now   Reply With Quote
Old 12-17-2012, 10:25 AM   #5
Special User
Rewards Points: 1,230
An engineered wood product such as MDF should be able to take the heat without warping. You could just route a bullnose and paint the shelf.
No kidding, please don't paint the window trim!
As for brackets, I would just use standard white steel 8" shelf brackets. They look like an L and are available at any home center for about $1/ea. Should be almost completely hidden by the radiator.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-17-2012, 10:34 AM   #6
Just set a piece of marble or granite on top of it.
Old 12-17-2012, 10:46 AM   #7
Rewards Points: 3,426
You can buy covers that have water pans in them to add humidity in winter,here's a link.
http://www.customradiatorenclosures.com/kdstyles.html
Canarywood1 is offline   Reply With Quote
Old 12-17-2012, 10:46 AM   #8
Special User
Ooh, that would look sharp. Might want to make little feet to keep an air gap to the radiator though, so you don't kill the airflow.
Old 12-17-2012, 11:29 AM   #9
Granite and/or marble typically cost between $30 & $75 per square foot. $200 to $400 per radiator just ain't going to happen.
Old 12-17-2012, 01:51 PM   #10
Rewards Points: 5,974
IMHO anything you would put that close to the radiator would not have a good effect as from the pics, room is very limited. And I believe (could be wrong) but the reason they put rads under windows is the cold air from the glass falls like behind the rad, is then heated and pushed out into the room and to place a shelf over it would alter this process. Maybe someone with a better knowledge of rads will come along.
Old 12-17-2012, 08:39 PM   #11
Rewards Points: 226
don't be so sure of that. if you can pic from the cut-off pile, and/or the place is slow. you may be able to get that piece for under $100
Old 12-18-2012, 07:01 AM   #12
DIY staff
Rewards Points: 7,174
A radiator shelf could be built----There would need to be a gap left at the back of the shelf
to allow for air circulation up to the windows--
I think a cleat screwed to the wall under the windows--attach the shelf---and use riser blocks on top
of the radiator to support the front
Good plywood ,finished on both sides should do---get it as high above the radiator as possible--
Add a nice solid wood edge band---
Old 12-18-2012, 07:39 AM   #13
Thread killer
Rewards Points: 272
Putting a shelf over your rad will reduce its output. Whether that reduces the comfort of the space would depend on a few factors. Check out the link.
http://www.heatinghelp.com/files/pos...Enclosures.pdf
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
