Radiator Question - Not Sure Which Forum To Post - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 11:44 AM   #1
Rewards Points: 174
Radiator question - not sure which forum to post
I installed a cast iron radiator in a second floor bedroom last year. When I purchased the house we did not realize that the room was missing the radiator. I found one on CL and installed it without a problem. Recently the radiator started to make gurggling noises as well as banging. I have a steam system so I know that water will collect in the radiators. But what I am hearing sounds like a lot of water inside of the unit.
Im not sure what I should do. Any suggestions?
Thanks.
Leoskee is offline   Reply With Quote
Old 12-30-2010, 02:11 PM   #2
Rewards Points: 5,336
Thanks.
Steam radiators need to be pitched so the water runs back down the supply pipe. Raise the side opposite the supply pipe so the radiator has a slight pitch. Put a level on it so you know.
Ron
Old 12-30-2010, 06:54 PM   #3
Rewards Points: 174
Wow. Never thought of that. I'll do that in a bit and hopefully that will take care of the issue.
Thanks.
