Radiant Heat Mixing Valve Size - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 04:03 PM   #1
radiant heat mixing valve size
I have two different heating techs that are recommending two different sizes of a mixing valve for my radiant floor heat. One says 3/4" the other says 1 1/4". I need to know which is the best option/correct. The house is new construction. The first floor has 5 loops of 1/2" PEX in concrete fed from 1 1/4" manifolds. The 2d floor will be heated with baseboard. One tech says 3/4" will cause problems, the other says "trust me" 3/4" is all you need. Appreciate any in put from those with experience with this type of set up.
dogbite is offline   Reply With Quote
Old 06-08-2011, 04:24 PM   #2
The way it sounds based on your project, a 3/4" mixing valve should be fine. If anything, you can choose 1" instead (i.e. Taco 5004-C2)
genie01 is offline   Reply With Quote
The Following User Says Thank You to genie01 For This Useful Post:
dogbite (06-13-2011)
Moving/Installing new mixing valve... issues with framing rodney23 Plumbing 6 12-12-2010 03:32 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Radiant heat question tpagel HVAC 4 05-21-2008 04:57 PM
bamboo over radiant heat montaillou Flooring 7 07-25-2007 01:17 PM
