Racing Seat Diy - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 06:13 AM   #1
racing seat diy
Hi all,
this is my first post in here thus hello
basically i have a racing seat for my gaming which was bought from openwheeler link to the chair is
http://www.openwheeler.co.uk/simulators/openwheeler-classic/
the chair comes with steering and pedal mounts but no place to mount gear shifter and hand brake
I should say that you can buy gear shifter add on but it does not have a place to mount the handbrake thus I have decided to do this my self and hence asking for help/suggestions
looking at the picture below which is a zoomed picture of my chair with the gear mount , mounted on the chair( I do not have this part) and mine seat picture is the last image in this post.
What I am planning to do(refer to figure 1) :
1.Buy 1x t square joint as depicted in red .
2.buy 1x 1 meter square tube as depicted in green and connected ti to the red square joint
I will then cut the meter to half and use the other half for the vertical part with the same idea of having another T square connecter in there
again I need another connector for the final part . that is my gear mount sorted
3. now time to sort my handbrake , I am planning to buy a metal bar and crew it into the squre tube half way through the tube as shown by black colour and then use metal corner joint to create a elbow and another bar straight thus I can mount my hand brake on it vertically as showen in blue colour( my hand brake mount place)
Now the problem I have is that ,
When I measured my white straight bar, the external diameter is 3cm (shown in brown) and the biggest T connector has an external diameter of 25mm on ebay which will not fit and this is where I am stock
Any idea on different way to do this etc ? or what I could buy the parts or if you think I should do it a different way
Many thanks
figure 1
my seat
random44 is offline   Reply With Quote
Old 02-15-2013, 11:45 AM   #2
280 view and no replies
Old 02-17-2013, 12:55 PM   #3
An old Tradesmen
Rewards Points: 6,500
Machine shop/fabrication shop should have plenty of ideas and ways.
Old 02-20-2013, 02:42 PM   #4
Ambidextrous klutz
Leprechaun's Avatar
Rewards Points: 38
Yep, most of us are just as stumped as you are. FWIW, I doubt that eBay is the best source for you. If you don't want to follow beenthere's suggestion, I suggest that you do a search for metal tubing vendors.
Leprechaun is offline   Reply With Quote
Old 02-20-2013, 05:03 PM   #5
PoleCat's Avatar
Rewards Points: 1,646
Nail that ****er to the floor!
PoleCat is offline   Reply With Quote
Shower valve seat insert Markthenovice Plumbing 0 12-23-2012 09:58 AM
Window seat between two built-ins under low window questions. noone Carpentry 27 02-16-2012 08:41 PM
bathtub leaking... seat housing cracked? olnoln Plumbing 12 05-21-2010 02:46 PM
Any Formula 1 (F1) or dirt track racing fans? concretemasonry Off Topic 10 02-13-2010 07:17 PM
