Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 05-26-2009, 02:12 PM   #1
quick question just need some help please.
i moved into an apartment and when my first roommate there was no problems with the door... but now that the second one is here, the door to her room makes an extremely loud noise when it opens... it sounds like if two things are stuck and then come apart... i looked at it the other day and the paint is somewhat coming off on the insides. the noise is really loud and its not a creak or anything its sudden and abrupt... well she smokes pot indoors but i tell her she must keep the window open... but im thinking that the smoke is the cause of this? if so can you explain why so that way i have some proof? and if its not the smoke what can it be? im tired of waking up 5 times every night because of her door
divine101 is offline   Reply With Quote
Old 05-26-2009, 03:04 PM   #2
Rub a white candle wax on the door edge and the frame. It should stop making the noise. It probably has nothing to do with the smoke and is most likely moisture that is causing the door and frame to swell just a little.
Rege
RegeSullivan is offline   Reply With Quote
Old 05-26-2009, 04:48 PM   #3
Old School
cabinetman's Avatar
The only way it could be the pot is if there's a joint stuck in the door jamb. Check the entire jamb and door where it closes and look for abrasion. It may have been recently painted or expanded with changes in the weather. You could use a candle as suggested, just about any lubricant, or even talc.
cabinetman is offline   Reply With Quote
Quick Question - Determining Which Wire is Which (both dead wires) Tryvidy Electrical 13 04-23-2009 07:00 PM
Quick HVAC / sump pump wiring question MattOverMinder Electrical 4 01-23-2009 08:42 AM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 12:21 PM
potentiometers...dials...quick question. plzfl8me Electrical 10 07-09-2008 04:26 PM
