Quick Change Bit Holder - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 08:42 PM   #1
Rewards Points: 1,654
I need to do a bunch of predrilling and driving screws.
I would like to use a bit holder that could "grab" on to a drill bit and a driver bit.
The ones I found would do exactly what I need.
The upper left item I would secure with my drill, then change from drill bit to driver bit and back and forth, it grabs onto the drill bit as I pull it back out in reverse, which a regular bit holder would not do.
The only problem is, and you get what you pay for, this set is only $6.99, and this quick change bit holder, after being used for 5 minutes, the shank and the holder goes out of alignment, meaning it would wobble badly as I spin the drill. This is basically a piece of junk.
Can someone recommend one I could buy that does a better job?
miamicuse is offline   Reply With Quote
Old 03-26-2012, 09:09 PM   #2
jschaben
Rewards Points: 502
I think this is what you are looking for
http://www.amazon.com/25PC-QUICK-CHA.../dp/B000XY2KGA
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 03-27-2012, 08:37 AM   #3
Learning Things Every Day
Jay 78's Avatar
Personally, I'd scrap that setup and get an impact driver and a quality (DeWalt/Milwaukee/Makita) bit set.
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-27-2012, 10:49 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
Impact driver? For drilling holes?
miami....I would suggest getting another drill....I have 5 drills...
2 Ryobi Cordless
1 Ryobi Angle drill
1 Ryobi corded drill
1 Skill 1/2" corded drill
All of the Ryobi's have keyless chucks...so changing bits is quick.
I will set up each drill with the required bit....then just cycle through the drills as I progress through a project. I typically use the corded drills for the heavy work...for example, drilling out the pocket for a pocket hole...that kind of stuff kills a battery quick.
ddawg16 is online now   Reply With Quote
Old 03-27-2012, 02:02 PM   #5
jschaben
Rewards Points: 502
Impact driver for drilling holes??? Why not just use tools for what they were designed?
Use a combo kit, drill bit in the drill, driver bit in the impact.
John Schaben
Old 03-27-2012, 03:41 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
impacts can be used for drilling holes.. bit manufacturers wouldnt be making bits for them if the tool couldnt handle it. but if your going to be using spade bits you need a actual drill
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Jay 78 (03-27-2012)
Old 03-27-2012, 03:53 PM   #7
Ravenworks's Avatar
And I thought I was bad.
jschaben,posted a good set I have one that is close to it,again you get what you pay for.
Ravenworks is offline   Reply With Quote
Old 03-27-2012, 07:12 PM   #8
The project I am going to do involve a lot of heads up on the ladder. I have two drills, I don't want to put two drills on a ladder and switch them back and forth.
Old 03-28-2012, 08:32 AM   #9
Jay 78's Avatar
Yes, and it's a more versatile and cost-effective solution than buying a new drill for each bit.
That's exactly what I do. There's no reason why an impact driver can't be used for lighter-duty drilling. Haven't you seen all those hex-shanked conversion chucks on the market? What do you think they're for? DeWalt, Milwaukee, Hitachi, Makita (and others) make them for use with their impact drivers.
http://www.amazon.com/s/ref=nb_sb_no...+chuck&x=0&y=0
Maybe I should have pointed out that impacts are fine for drilling within reason. As mentioned, spade bits don't really work, and I wouldn't even attempt to chuck up any of my big masonry bits to it, but it's still a 'dumb' tool, meaning as long as it's not being overworked, it doesn't know/care what work it's being used for. An impact driver will handle all those dainty hex-shanked drill bits pictured above with ease.
Under Construction
Old 03-30-2012, 05:19 AM   #10
Send a message via ICQ to Juchara
well don
Well done! I especially like that
Juchara is offline   Reply With Quote
Old 03-30-2012, 06:23 AM   #11
If you want an answer to the question you asked. There is a company called Snappy drill. They make very high quality quick release chucks, countersinks, bits, and accessories. Woodcraft sells them. Take a look
robs660 is offline   Reply With Quote
The Following User Says Thank You to robs660 For This Useful Post:
Ravenworks (03-30-2012)
Old 03-30-2012, 07:32 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,262
I have had good luck with this Craftsman (Sears) set:
http://www.sears.com/shc/s/p_10153_1...8&blockType=G8
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 04-12-2012, 09:36 PM   #13
Jay 78's Avatar
Under Construction
Old 04-13-2012, 02:27 PM   #14
Rewards Points: 242
No you don't...I used 1 inch and half inch spade bits in my DeWalt 18V impact driver to drill though 58 year old framing when I wired my bathroom...the impact driver never went into impact mode...worked like a champ...equal or better than my cordless drills, even through hard old double 2x4's.
You can't be using tired, old, worn out bits...
Just FYI...quick change bit/driver tool...you might try this option...I've used it many times and it works great. I think Black and Decker makes the same thing only cheaper...or it used to be. Hmmm, forgot that BD and DeWalt are now the same...oh well.
http://www.amazon.com/DEWALT-DW2730-...uct/B000056H9O
Ed911 is offline   Reply With Quote
The Following User Says Thank You to Ed911 For This Useful Post:
Jay 78 (04-13-2012)
Old 04-13-2012, 04:13 PM   #15
ive done it myself. but its much harder on the bits and its not good on the impact driver. their designed for use in a drill. this is both from experience and through talking to the reps for bosch, makita and dewalt
jschaben (04-13-2012)
Story time - Flying rossfingal Off Topic 195 03-16-2012 11:59 PM
Apartment- Connect portable washer straight to sink drain + double quick connect? DrDreams Plumbing 1 03-14-2012 08:30 AM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 09:38 AM
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 06:41 PM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 06:54 PM
