Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-21-2010, 07:55 AM   #1
Question on oil base stain
Has anyone used Flood's Clear Wood Finish CWF? What is your thought's on this product? I am using it on Western Red Cedar shingles... P.S. This the natural or clear product.
pakron is offline   Reply With Quote
Old 03-21-2010, 04:45 PM   #2
Consumer's Reports does stain comparisons. Check to see which stains were highly rated and use one of those.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
pakron (03-21-2010)
Old 03-21-2010, 08:25 PM   #3
i used it once on resawn 2x6 framing lumber for board and batten with roughsawn side out. turned golden orange
The older I get the better I was
Old 03-22-2010, 04:00 AM   #4
paper hanger and painter
chrisn's Avatar
Ron
I do not know much about stains but I do know that consumer reports Behr as the #1 paint, so I would put absolutely no trust in what they have to say about paint products.
chrisn is online now   Reply With Quote
Old 03-24-2010, 08:42 PM   #5
water flows downhill
oarfish's Avatar
Flood is good product. I used the CWF clear in the late eighties on unfinished rough wood siding.
Was very liquid, hard to apply without dripping, or lots of "clouds" in the neighborhood when spraying. It was expensive also compared to Thompson water sealer that was popular those days.
I personally have not found a clear material that would protect the beauty of unfinished wood in a long run from darkening and staining.
oarfish is offline   Reply With Quote
Very simple stain question. dntnowood Painting 5 01-30-2010 07:37 AM
Base Board Trim cambishop Carpentry 10 01-23-2010 09:43 AM
Shower base problem Gregor24 Plumbing 3 01-15-2010 10:34 PM
Base Moulding Question diykc General Discussion 8 01-13-2010 10:09 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
