Question On Bathroom Flooring - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 11:12 AM   #1
Question
Question on bathroom flooring
Hello everyone
I am in the process of redoing my bathroom next to my main bedroom. The floor space is very minimal. The whole bathroom is only 6 feet by 8 feet. and most of the floor is taken up by shower, vanity, and stool. I was wondering what kind of flooring except tile could I put down that I could put a heating element under to warm the floor?
noviceshock is offline   Reply With Quote
Old 04-02-2012, 02:20 PM   #2
Rewards Points: 1,092
I think you've found the flooring. Use nothing that is glued down, like vinyl, as the heat will probably be too much for the glue. (that, of course, depends on how warm you want the floor, and how much insulation is under it, etc). Just ensure that the subfloor is skookum enough for tile.
Old 04-02-2012, 08:33 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
if our using infloor heat. tile is pretty much your only option.. engineered hardwood flooring can go over in floor heat however should not be installed in a bathroom.. wood and water dont mix
woodworkbykirk is offline   Reply With Quote
bathroom flooring carebear560 Flooring 9 07-24-2012 07:12 PM
Vinyl over Terrazzo Flooring in Bathroom? Amy Lou Flooring 0 02-15-2012 10:07 PM
Female with Basement Flooring Question smilekl Flooring 0 02-14-2012 02:12 PM
New Bathroom Drain Question militaryman Plumbing 1 01-06-2011 09:09 AM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
