Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-07-2008, 01:26 PM   #1
Question with basement walls
Hi everyone, my husband and I just moved into our home and this summer I am working on cleaning up the place before I start my mini-remodeling projects I have on my list of things we would like done.
I am currently cleaning the basement which does not look to have ever been cleaned since the property was constructed in 1936.
There is a huge humidity problem and we are the process of getting a dehumidifier up and going. In the mean time I am breaking up storage sheds that were there. My question is ........on the concrete walls I see pink stuff, like stains of sorts, is this mildew? does anyone know what this is? How do I clean it? I am guessing just bleach and water.
Question with basement walls-basement-shed-area-2.pg.jpg   Question with basement walls-basement-shed-area.jpg
OUDIDIT2 is offline   Reply With Quote
Old 07-07-2008, 06:43 PM   #2
Moderator
Termite's Avatar
It could be mold/mildew of some sort, it could be effloressence, it could be anything.
I'd suggest mixing some bleach and water as a cleaning solution, or use something like TSP to clean the walls. There are some mold/mildew removal chemicals on the market as well, but I can't think of the name.
Getting the dehumidifier going will work wonders if there's a mold situation.
Old 07-08-2008, 07:14 AM   #3
Ive also read on the Internet that using white distilled vinegar 5% dilution is as good if not better than using bleach. I tried this and it removed the mold fairly well. I guess the bleach is wwatered down from the factory and if you add more water then you are actually supplying the mold/mildew with more water/moisture and it will actually proliferate more. Try a Google search for cleaning with vinegar. Lastly if it is efflourssence, a clacium deposit, vinegar will disolve it as it is a mild acid, you will hear it bubbling like Rice Krispies
creamaster is offline   Reply With Quote
Old 07-08-2008, 11:24 AM   #4
Thanks Thekctermite & Creamaster for your input. I just purchased some TSP and will treat it as mold and mildew then try an etch cleaner if it is effloressence. I never heard of using vinegar, interesting. I use vinegar to kill some weeds out in the backyard.....stuff works.
I put a product called DRYLOK by UGL on 3/4 of the basement walls and floors and it has cut down on the humidity alot. I am really pleased with this product. But in this corner and the laundry area I will be using a product called Zinsser Watertite. I just did not have any of the pink stuff until I tore down this shed. I did wash all the walls down with a heavy bleach solution only because it's the first time I am cleaning the basement and I didn't know what was down there.
Thanks again!
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
basement walls citimauler General Discussion 1 02-14-2008 08:18 AM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
